25
This all started happening after upgrading to 13.10, now I am running 14.04 and still have the same issue.
When I close the lid or I do sudo pm-suspend the laptop goes into suspend for 2-5 seconds and awakes by itself.
Same happens if I try to do hibernate.
I have a gut feeling that something is awaking/taking the cpu out of suspend mode but I cannot figure out what.
Any help troubleshooting this annoying issue?
Edit:
Thanks to @Fabian , I was able to figure out that it looks like the ethernet card is misbehaving and even after I set the card to not wake up on lan (either doing acpitool -W 3 or echo disabled > /sys/bus/pci/devices/0000:00:19.0/power/wakeup or echo IGBE > /proc/acpi/wakeup, the laptop keeps waking up and showing this when I do acpitool -w
Device  S-state   Status   Sysfs node
1. LID    S3    *enabled
2. SLPB   S3    *disabled
3. IGBE   S4    *enabled   pci:0000:00:19.0
4. EXP1   S4    *disabled  pci:0000:00:1c.0
5. EXP2   S4    *disabled  pci:0000:00:1c.1
6. EXP3   S4    *disabled
7. EXP4   S4    *disabled
8. EXP5   S4    *disabled  pci:0000:00:1c.4
9. EHC1   S3    *disabled  pci:0000:00:1d.0
10. EHC2      S3    *disabled  pci:0000:00:1a.0
11. HDEF      S4    *disabled  pci:0000:00:1b.0
Any idea how to proceed from there?
The network driver that IGBE uses is e1000e
feniix
  • 494
5 Answers5
12
The following worked for me:
cat /proc/acpi/wakeup
Look for any items with status enabled that look like they don't belong there (for me, anything except LID0). Then disable them by saying, for example:
sudo sh -c "echo XHC0 > /proc/acpi/wakeup"
Check that the corresponding entries have indeed been disabled, send the laptop into suspend and hope for the best :)
Fabian
  • 121
10
I have kernel 13.13 and Intel Z77X based motherboard, and following command works for me:
sudo sh -c "echo EHC1 > /proc/acpi/wakeup;echo EHC2 > /proc/acpi/wakeup;echo XHC > /proc/acpi/wakeup"
muru
  • 207,228
guest
  • 116
Experiencing exactly the same problem (ThinkPad T530, Ubuntu 14.04, but also 13.10 and 13.04, after couple of suspends, computer resumes immediately after suspend).
Disabling IBGE from wakeup did not help at all.
As suggested by Romano, I've tried removing the e1000e module, et voila suspend as expected.
So:
sudo rmmod e1000e
prior to suspend resolves the issue.
Interestingly, the problem reappears immediately after installing the module back (sudo modprobe e1000e) and suspending without its removal. So, it must've been something related to hardware.
To automate it, I've created two simple suspend/wakeup scripts (tested on the above mentioned hardware, Ubuntu Trusty 14.04): sudo gedit /etc/pm/sleep.d/99_e1000e_remove :
#!/bin/sh
# Remove e1000e kernel module prior to suspend
rmmod e1000e
and sudo gedit /etc/pm/power.d/99_e1000e_probe :
#!/bin/sh
# Modprobe e1000e kernel module after resume
modprobe e1000e
Scripts should be executable (sudo chmod +x /etc/pm/sleep.d/99_e1000e_remove /etc/pm/power.d/99_e1000e_probe).
Notes:
  • I assume the scripts are pretty safe to use even when it does not address your problem.
  • I'm not using LAN wakeup, so I don't know how it behaves with the fix.
This worked for me (taken from another thread on askubuntu):
Ubuntu 14.04 wake up immediately after suspend
You can try to disable it with a Upstart script every startup automatically:
Create a file etc/init/disable-XHC.conf
Content:
start on started dbus
stop on stopping dbus
script
   sudo -u root sh -c "echo 'XHC' > /proc/acpi/wakeup"
end script
Ilian
The systemd solution is to create an instruction for systemd-tmpfiles to write something to a file when it is invoked.
Create a file in /etc/tmpfiles.d, e.g. /etc/tmpfiles.d/disable-network-wake.conf, with the following content, depending on what device you want to disable wakeup for.
w /proc/acpi/wakeup - - - - XHC
See also systemd-tmpfiles(8) and tmpfiles.d(5).
Ref: https://wiki.archlinux.org/index.php/Systemd#Temporary_files
