after upgrading to 14.04, Ruby was downgraded to 1.8.3 so I tried to upgrade using the following commands.
sudo apt-get install libgdbm-dev libncurses5-dev automake libtool bison libffi-dev
curl -L https://get.rvm.io | bash -s stable
source ~/.rvm/scripts/rvm
echo "source ~/.rvm/scripts/rvm" >> ~/.bashrc
rvm install 2.1.1
rvm use 2.1.1 --default
ruby -v
After that i ran
sudo gem install jekyll
It was installed sucessfully but, I am not able to use it is says
bash: /usr/local/bin/jekyll: /usr/bin/ruby1.9.1: bad interpreter: No such file or directory
Anandu
  • 23
Install ruby1.9.1-dev for Jekyll
sudo apt-get install ruby1.9.1-dev
If you have other version of Ruby, remove it first.
i.e for Ruby 2.0
sudo apt-get purge ruby2.0*
It appears that ruby might not be installed at the searched location. Try:
$ sudo apt-get install ruby
Also you gave a command that you tried, "ruby -v". Can you give us the output of that command?
L. D. James
  • 25,444
