I found a solution, quiet not as good as iTunes but it worked :P
First install and update mpd:
sudo apt-get update
sudo apt-get install mpd
then you need pulseaudio
sudo apt-get install pulseaudio pulseaudio-module-zeroconf
sudo vi /etc/default/pulseaudio
PULSEAUDIO_SYSTEM_START=1
DISALLOW_MODULE_LOADING=0
start pulseaudio
sudo /etc/init.d/pulseaudio start
(if you want to test your settings:
paplay /usr/share/scratch/Media/Sounds/Vocals/Singer1.wav
you may get errors like:
pa_context_connect() failed: Connection refused
sudo vi /etc/environment
PULSE_SERVER=localhost
sudo vi /etc/pulse/daemon.conf
resample-method = trivial
default-sample-rate = 48000
sudo vi /etc/pulse/system.pa
#load-module module-suspend-on-idle
load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;192.168.0.0/24
auth-anonymous=1
load-module module-zeroconf-publish
backup you /etc/asound.conf file
and create a new asound.conf
sudo vi /etc/asound.conf
pcm.pulse {
type pulse
ctl.pulse {
type pulse
pcm.!default {
type pulse
ctl.!default {
type pulse
sudo vi /etc/libao.conf
default_driver=pulse
quiet
Install shairport
sudo apt-get install git libao-dev libssl-dev libcrypt-openssl-rsa-perl libio-socket-inet6-perl libwww-perl avahi-utils libmodule-build-perl
sudo cpan install Net::SDP
git clone https://github.com/albertz/shairport.git shairport
cd shairport
make
sudo make install
sudo cp shairport.init.sample /etc/init.d/shairport
sudo chmod a+x /etc/init.d/shairport
sudo update-rc.d shairport defaults
configure shareport
sudo vi /etc/init.d/shairport
NAME=AirPi
USER=pulse
DAEMON="/usr/local/bin/shairport.pl"
PIDFILE=/var/run/pulse/$NAME.pid
DAEMON_ARGS="-w $PIDFILE -a $NAME"
[ -x $binary ] || exit 0
RETVAL=0
start() {
echo -n "Starting shairport: "
start-stop-daemon --start --quiet --pidfile "$PIDFILE" \
--chuid $USER \
--exec "$DAEMON" -b --oknodo -- $DAEMON_ARGS
log_end_msg $?
start and enjoy :)
sudo /etc/init.d/shairport start
Source (all credits go to them):
http://mpd.wikia.com/wiki/Install
and
http://www.foell.org/justin/raspberry-pulse/#comment-1991
greetings Kaito
