Yesterday I installed 14.04 on my dell latitude e6430. After the instalation when system started mouse pointer is not visible and the touchpad and mouse are, hence, useless.
How do I resolve this?
Charo
  • 3,681
I was having the exact same problem on my Thinkpad x120e after a fresh install of ubuntu-14.04-desktop-amd64 (64 bit Ubuntu). I would log into Ubuntu and the mouse would disappear, right click wouldn't do anything, and all of the other remedies that I saw posted didn't have any effect.
What worked for me:
I did a clean install Ubuntu 14.04 32-bit edition instead of the recommended 64-bit version. It works great now!
Another user mentioned that a bit more background on this may be helpful. Here goes, a post under the question: 'what-are-the-differences-between-32-bit-and-64-bit-and-which-should-i-choose' talks about some key differences 32 bit and 64 bit and an obvious one is compatibility... 32 bit is generally more compatible with everything.
The practical problem: not everyone has a AMD64 compatible CPU. Promoting 64-bit over the standard i686 version would lead to more user frustration. Therefore for the next few years, it's less confusing to present the 32-bit version to the average user. It's not exactly a problem for anyone in the know, since the 64-bit version is readily available. And we amd64 users don't have any disadvantage from that situation, except for the initial download. All packages are available in both architectures.
https://askubuntu.com/a/7084/284653
Not saying for sure that the mouse pointer disappearing was due to an architecture issue but it does seem to fit for this instance. Hope this works for you.
Pang
  • 373
Ben L
