I have upgraded to Kubuntu 14.04 from 13.10 today. I found that my third party webcam packages were deleted during upgrade. I was using linuxtv drivers, so I followed the instructions given on this page.
I executed following commands in terminal
git clone git://linuxtv.org/media_build.git
cd media_build
./build
The following is the output of executing ./build:
Checking if the needed tools for Ubuntu 14.04 LTS are available
Needed package dependencies are met.
* This script will download the latest tarball and build it*
* Assuming that your kernel is compatible with the latest  *
* drivers. If not, you'll need to add some extra backports,*
* ./backports/<kernel> directory.                          *
* It will also update this tree to be sure that all compat *
* bits are there, to avoid compilation failures            *
* All drivers and build system are under GPLv2 License     *
* Firmware files are under the license terms found at:     *
* http://www.linuxtv.org/downloads/firmware/               *
* Please abort in the next 5 secs if you don't agree with  *
* the license                                              *
Not aborted. It means that the licence was agreed. Proceeding...
Updating the building system
From git://linuxtv.org/media_build
* branch            master     -> FETCH_HEAD
Already up-to-date.
make: Entering directory `/tmp/media_build/linux'
wget http://linuxtv.org/downloads/drivers/linux-media-LATEST.tar.bz2.md5 -O linux-media.tar.bz2.md5.tmp
--2014-04-18 07:10:34--  http://linuxtv.org/downloads/drivers/linux-media-LATEST.tar.bz2.md5
Resolving linuxtv.org (linuxtv.org)... 130.149.80.248
Connecting to linuxtv.org (linuxtv.org)|130.149.80.248|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 101 [application/x-bzip2]
Saving to: ‘linux-media.tar.bz2.md5.tmp’
100%[====================================================>] 101         --.-K/s   in 0s
2014-04-18 07:10:34 (5.67 MB/s) - ‘linux-media.tar.bz2.md5.tmp’ saved [101/101]
make: Leaving directory `/tmp/media_build/linux'
tar xfj linux-media.tar.bz2
rm -f .patches_applied .linked_dir .git_log.md5
* Downloading firmwares from linuxtv.org.                *
dvb-fe-bcm3510-01.fw
dvb-fe-or51132-qam.fw
dvb-fe-or51132-vsb.fw
dvb-fe-or51211.fw
dvb-fe-xc5000-1.6.114.fw
dvb-ttpci-01.fw-261a
dvb-ttpci-01.fw-261b
dvb-ttpci-01.fw-261c
dvb-ttpci-01.fw-261d
dvb-ttpci-01.fw-261f
dvb-ttpci-01.fw-2622
dvb-usb-avertv-a800-02.fw
dvb-usb-bluebird-01.fw
dvb-usb-dib0700-1.20.fw
dvb-usb-dibusb-5.0.0.11.fw
dvb-usb-dibusb-6.0.0.8.fw
dvb-usb-dtt200u-01.fw
dvb-usb-terratec-h5-drxk.fw
dvb-usb-terratec-h7-az6007.fw
dvb-usb-terratec-h7-drxk.fw
dvb-usb-umt-010-02.fw
dvb-usb-vp702x-01.fw
dvb-usb-vp7045-01.fw
dvb-usb-wt220u-01.fw
dvb-usb-wt220u-02.fw
v4l-cx231xx-avcore-01.fw
v4l-cx23418-apu.fw
v4l-cx23418-cpu.fw
v4l-cx23418-dig.fw
v4l-cx23885-avcore-01.fw
v4l-cx23885-enc.fw
v4l-cx25840.fw
* Start building *
make -C /tmp/media_build/v4l allyesconfig
make[1]: Entering directory `/tmp/media_build/v4l'
make[2]: Entering directory `/tmp/media_build/linux'
Applying patches for kernel 3.13.0-24-generic
patch -s -f -N -p1 -i ../backports/api_version.patch
patch -s -f -N -p1 -i ../backports/pr_fmt.patch
The text leading up to this was:
|diff --git a/drivers/media/usb/gspca/dtcs033.c b/drivers/media/usb/gspca/dtcs033.c
|index 5e42c71..ba01a3e 100644
|--- a/drivers/media/usb/gspca/dtcs033.c
|+++ b/drivers/media/usb/gspca/dtcs033.c
No file to patch.  Skipping patch.
1 out of 1 hunk ignored
make[2]: *** [apply_patches] Error 1
make[2]: Leaving directory `/tmp/media_build/linux'
make[1]: *** [allyesconfig] Error 2
make[1]: Leaving directory `/tmp/media_build/v4l'
make: *** [allyesconfig] Error 2
can't select all drivers at ./build line 490.
I don't really know how to proceed from this point. If someone have solution to this problem kindly let me know.
I managed to convince the build to go forward. It seems to compile fine so far... fingers crossed...
Here's what I did: I opened backports/pr_fmt.patch, remove everything following diff --git a/drivers/media/usb/gspca/dtcs033.c, then ran build again.
patch -p1 <<EOF
diff --git a/backports/pr_fmt.patch b/backports/pr_fmt.patch
index d13d516..edc698f 100644
--- a/backports/pr_fmt.patch
+++ b/backports/pr_fmt.patch
@@ -1174,15 +1174,3 @@ index a99040b..8ff1ed7 100644
  #define pr_fmt(fmt) KBUILD_MODNAME ":%s: " fmt, __func__
  #include <linux/module.h>
-diff --git a/drivers/media/usb/gspca/dtcs033.c b/drivers/media/usb/gspca/dtcs033.c
-index 5e42c71..ba01a3e 100644
---- a/drivers/media/usb/gspca/dtcs033.c
-+++ b/drivers/media/usb/gspca/dtcs033.c
-@@ -14,6 +14,7 @@
-  * GNU General Public License for more details.
-+#undef pr_fmt
- #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
- #define MODULE_NAME "dtcs033"
- #include "gspca.h"
EOF
Noosrep
  • 2,184
