I have Windows 8.1 on my HP Pavilion G6 and would like to replace windows with Ubuntu 14.04 but what option do I choose when it comes to the installation part? I noticed it wont detect my Windows 8.1 so should that matter if im going to replace it with Ubuntu? Should i choose the Erase Disk option and then install? Secure Boot and Fastboot and all other options have been taken care of but would like some further instructions from someone a little more experienced.
If you use the option labeled "Guided - Use entire disk and setup LVM" and then keep clicking Yes or Next, then everything will install just fine.
keep in mind that this will erase everything on your disk.
- 316
i see Use LVM with the new Ubuntu installation and Erase disk and install Ubuntu. Which option do i choose?
Choose Erase disc and Install Ubuntu and make sure the other LVM Encryption option is selected below. When it comes to re-installing Windows 8.1 if you have recovery discs you shouldn't have a problem re-installing Windows. If you don't have any recovery discs you can create them within Windows just do a search [Windows + S] at the desktop for recovery disc. You will need 3 blank DVDs FYI. Instead of getting rid of Windows completely you can always dual-boot your machine. If you have yet to install Ubuntu you can re-partition your C: Drive, search for disc partitioner, and allocate some memory from the C: drive for Ubuntu. Reboot and install Ubuntu on this new partition and you should have a dual booting machine with Windows & Ubuntu. Of course if that seems too much for you installing Ubuntu solely by itself is the easiest thing to do.
