NOTE: THIS IS NOT A DUPLICATE QUESTION. It is specific to Foldit.tar.gz and installing this game is done uniquely. There is an askubuntu page answering the question, "How do I install a .tar.gz (or .tar.bz2) file?", but those instructions are for that generic file type. They don't work with this particular game, and in this explanation I've resolved that. Also, I'm an absolute beginner, running Ubuntu 13.01 for only about 2 months now. I'm only barely familiar with the console at this point. Please bear with me. However, what I offer is the simplest and most concise solution to this problem you will find (out of the first 50 or so google results that come up).
1- From your Downloads folder right click the downloaded file "Foldit.tar.gz" and select the option to extract it into any folder you choose. I picked /Public/Foldit in my home folder.
2- The next step is easiest done from the console. Type in sudo apt-get install xclip
which enables you to cut and paste within the game. (It should run without this feature, if you don't want it.) Then type this in to start it sudo xclip
3- Next type in sudo apt-get install libglut3 which is a prerequisite not mentioned on the fold.it site nor in the readme file. (I asked them to change that, but who knows.) If that command didn't work, like it didn't for me, then go to this page to download the libglut3 package, ubuntu packages, which I was then able to install via the software center. There, you should be all set.
4- Before you try to start the game, make sure you're on-line so it can download all the updates and puzzles. The readme file says, "To start the game, run Foldit from this directory." So go into the folder where you put the original download extracted, and double click Foldit. If it doesn't work completely for any reason (like it didn't for me), restart ubuntu, and try this step again. For me, Foldit wouldn't load up some of the puzzles, but on my 3rd try, it worked perfectly and has ever since.
Don't you love it when you wind up answering your own question? Thank you to everyone that showed and interest and/or helped me.
b-girl
  • 61
thank you, libglut3 doesn't exist (anymore?), install freeglut3 instead... and it worked for me!
The following instructions are inspired from foldit.fandom and worked for me on Ubuntu 22.04.05:
For Linux there is no installer. Just untar the file (sudo tar -xzf Foldit-linux_x64.tar.gz), cd into the directory (cd Foldit/), and type ./Foldit or double click on the Foldit icon in the Foldit folder (within a long list of files).
If nothing happens (or if you get an error like "Foldit Error: Could not load library: libglut.so.3: cannot open shared object file: No such file or directory"), you need to install the freeglut3 package.
In Ubuntu you can install it via the Software Center or the Synaptic Package Manager, or by typing the following in a terminal:
sudo apt-get install freeglut3
sudo apt-get install libglut3 (alternatively)
The following packages could also help:
sudo apt-get install libnss-mdns
There is a possibility that on first login the username cannot be entered. Clicking on the check boxes will show the username box!
multiglup
