The problem is the following (from man apt-get):
install
install is followed by one or more packages desired for
installation or upgrading. Each package is a package name, not
a fully qualified filename (for instance, in a Debian system,
apt-utils would be the argument provided, not
apt-utils_0.9.12.1_amd64.deb). All packages required by the
package(s) specified for installation will also be retrieved
and installed. The /etc/apt/sources.list file is used to locate
the desired packages. If a hyphen is appended to the package
name (with no intervening space), the identified package will
be removed if it is installed. Similarly a plus sign can be
used to designate a package to install. These latter features
may be used to override decisions made by apt-get's conflict resolution system.
So, adding a hyphen to the end of a package name means "remove that package". Specifically, in your case, it would remove these:
Note, selecting 'libgtk2.0-doc' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-cil' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-bin' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-common' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-0' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-cil-dev' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-0-dbg' for regex 'libgtk2.0'
Note, selecting 'libgtk2.0-dev' for regex 'libgtk2.0'
In other words, you removed the entire gtk2 library set, and a lot of programs depend on gtk2. As a result, a lot of programs were removed.
So, no, this is not a bug. It is, admittedly, surprising behavior if you don't know about it but it is documented and intended.
