I set up external flash drive to run ubuntu. How do I get it to work and not load windows XP?
Asked
Active
Viewed 30 times
You should be able to go into your BIOS at startup and select which drive to bout off of. It varies widely from model to model but typically if you press F10 or F12 when you see the computer manufacture's logo the BIOS should pop up.
From here your can use the arrow keys to navigate to "boot options" (or something similarly named) where you can select the appropriate drive.
codedude
- 592
