25
I'm using Ubuntu 12.04. I do not have any root or sudo privileges as this is a company machine.
Is there, in a normal installation of Ubuntu 12.04, any terminal program that I can use to turn ugly malformed source code that lacks any indentation into nice looking code?
Again, I can't install any packages so I need one that already comes with Ubuntu, if such a thing exists.
For example:
    int main()
test(1);
another_function(1);
And then convert it to:
int main()
    test(1);
user9993
  • 389
6 Answers6
16
clang-format is your friend! Its easy to use and useful.
Here are some information about it.
Usage
$ clang-format file > formattedfile
Or:
$ clang-format -i file
Step by step guide
1. Horribly formatted code
#include <iostream>
  using namespace std;
    int main() {
         cout << "Oh";
      cout << "clang format rulez!";
main.cc
2. Magical command
$ clang-format -i main.cc
3. Well formatted code
#include <iostream>
int main() {
  cout << "Oh";
main.cc
4. Happiness
Installing
If you like it, you can install it with,
$ sudo apt-get install clang-format
command.
mraron
  • 261
14
If you have the vim editor installed, open the file with vim file.c and type =G to indent the file from begin to end. Then save it with :wq.
On default installations, vi (not vim) is installed, so it will not have the required ident package (as mentioned by karel).
JZL003
  • 243
Lekensteyn
  • 178,446
Open the terminal and run:
sudo apt-get install indent
indent -linux -l120 -i4 -nut unformatted-source-code.cpp
...where unformatted-source-code.cpp is the file that has unformatted C++ source code, such as the code in your example.
Or if you can't install it, you can download the package with apt-get download indent and extract it: dpkg-deb -x indent*.deb fs/, the indent binary is located in fs/usr/bin/ where fs is any directory in your home directory. If you copy the unformatted-source-code.cpp file to the same place, fs/usr/bin/ , then the commands to indent the code from the terminal are:
cd path/to/fs/usr/bin/  # change directories to the location of "indent" executable
./indent -linux -l120 -i4 -nut unformatted-source-code.cpp
These commands can be run as normal user. It is not necessary to be root.
karel
  • 122,292
  • 133
  • 301
  • 332
By default nano should be installed in ubuntu.
You can use nano -i file to edit with auto-indent enabled.
This may not change existing lines, for that you may have to manually indent it.
See: http://www.nano-editor.org/dist/v2.0/nano.html
Avinash R
  • 179
astyle and indent spring to mind, but a default Ubuntu install doesn't include either. Of course, if you have a C compiler, you can compile them and install them in your own PATH somewhere.
# Something like -
./configure --prefix=$HOME/tools
make
make install
PATH=$PATH:$HOME/tools/bin
emacs :
  • open c file
  • select all
  • indent ( tab key)
  • save file
HTH
Adam
  • 379
