Every time I plug/unplug the power cable docky is closing. This thing is happening since I have updated to 14.04, also, my battery life seems to be shorter. I am using a toshiba satellite c55-A-1PX.
You should write a pm script as described in this page:
http://www.linux-compatible.com/tutorial/docky-closes-after-waking-suspend-ubuntu
    - 168
Original credit goes to linux-compatible.com
This is just an attempt to enhance the script a bit. I my case Docky was also crashing when laptop lid was opened/closed.
replace gedit with pluma if you're running Mint
gksudo gedit /etc/pm/sleep.d/20_docky
#!/bin/sh
case $1 in
    resume)
    if grep -q open /proc/acpi/button/lid/*/state
    then
        USER=`who | grep ":0" | head -1 | cut -d" " -f1`
        USERHOME=/home/$USER
        export XAUTHORITY="$USERHOME/.Xauthority"
        export DISPLAY=":0"
        su $USER - -c "dbus-launch /usr/bin/docky >/dev/null" &
        exit 0;
    fi
esac
$ sudo chmod ugo+x /etc/pm/sleep.d/20_docky
next...
gksudo gedit /etc/pm/power.d/20_docky
#!/bin/sh
then
    export DISPLAY=":0"
    exit 0;
fi
$ sudo chmod ugo+x /etc/pm/power.d/20_docky
also...
gksudo gedit /etc/acpi/events/lid
event=button[ /]lid
action=/etc/acpi/lid.sh
finally...
gksudo gedit /etc/acpi/lid.sh
#!/bin/sh
then
    if [ -z "$(pgrep docky)" ]
    then
        export DISPLAY=":0"
        exit 0;
    fi
fi
sudo chmod ugo+x /etc/acpi/lid.sh
That's it. You may also want to remove Docky from startup programs, else it might attempt to start twice.
Good luck.
    - 21
There is an alternative to the methods mentioned here. Since a few days, that is. see: https://launchpad.net/~docky-core/+archive/ubuntu/stable
There have been a few bug-fixes and improvements to the release you normally get when installing via software sources bundled with your distro.
To install the latest stable build add this ppa to your repositories:
ppa:docky-core/stable
Full copy-pasta would be: (sudo not included)
add-apt-repository ppa:docky-core/stable && apt-get update
apt-get purge docky
apt-get install docky
    - 51
a modified script to avoid multiple docks on resume/lid open. simply it checks if docky is already executed
/etc/pm/sleep.d/20_docky:
#!/bin/sh
case $1 in
    resume)
    then
        export DISPLAY=":0"
        check=$(pidof mono /usr/bin/docky.exe | grep -c "")
        if [ $check -lt 1 ]; then
        else
            exit 0;
        fi
    fi
esac
and
/etc/pm/power.d/20_docky:
#!/bin/sh
export DISPLAY=":0"
else
    exit 0;
fi
this slighlty modified script works perfectly for me on Linux Mint 17.3 Rosa
    - 207,228
