I need to install the package ffmpeg because I am trying to install subsonic server on my new Ubuntu Gnome 14.04
When I try:
apt-get install ffmpeg
I get:
ffmpeg : Depends: libavcodec54 (>= 7:1.2.5~) but it is not going to be installed or
libavcodec-extra-54 (>= 7:1.2.5~) but it is not going to be installed
Depends: libavdevice53 (>= 7:1.2.5~) but it is not going to be installed
Depends: libavfilter3 (>= 7:1.2.5~) but it is not going to be installed
Depends: libavformat54 (>= 7:1.2.5~) but it is not going to be installed
I have tried
apt-get -f install ffmpeg
apt-get install --fix-broken
apt-get autoclean
apt-get autoremove
With no luck at all. I found a repository and added it to my sources via:
add-apt-repository ppa:jon-severinsson/ffmpeg
With still no luck. I found this question Is FFmpeg missing from the official repositories in 14.04? which led me to try this:
apt-get install libav-tools
which resulted in this:
libav-tools : Depends: ffmpeg (>= 7:0.10~) but it is not going to be installed
I also have made sure my "Software & Updates" have all the proper repositiories checked off, namely all 4 on the "Ubuntu Software" tab, and all on the "Other Software" tab with the exception of the second one (Canonical Partners Source Code). I also have these checked off as well per instructions supplied on the page they lead to:
http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu saucy main
http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu trusty main
None of this works. How can I install ffmpeg? Or if I cannot install it, what do I need to install to replace its functionality?
