My wifi works fine on my Lubuntu system, but is there a way to make it forget the wifi login credentials after a user logs out? I need other users to sign in with their own (web authorization page-) credentials if they login.
Lubuntu uses NetworkManager. This explaines how to delete a know network.
sudo rm /etc/NetworkManager/system-connections/NETWORK_NAME
If I understand correctly from this source, run-level 5 is for graphical logins:
Run levels 2 through 5 are full multi-user mode and are the same in a default UserLinux (Debian) system. It is a common practise in other Linux distributions to use run level 3 for a text console login and run level 5 for a graphical login.
You wrap the above command in a executable script and link it to /etc/rc5.d/your_script.
A little more information can be found in this answer
Addressing the distraction first
In the dialog between 'mercmanager2' and 'OrangeTux' there seems to be some miscommunication. I'm not sure I understand the confusion clearly, but it looks to me like 'mercmanager2' is confusing the wifi access point login with a website login.
Network Manager does indeed remember access point credentials. For a single user system, this is a huge convenience. If you want to delete an access point, right click on the network manager, select 'edit connections', then select the wifi tab, select the access point, and click delete.
If you want this to happen automatically, "OrangeTux's" advice is correct, but will only take place on power down, depending on how you attach it to the rc.5 daemon, which by the way is not for the faint of heart.
Browser configurations, in contrast, are kept in the user login home directory and are absolutely isolated. If I log into a bank, then log out and another family member logs into their SEPARATE user account, they will absolutely be automatically connected to the wifi access point. They will NOT however have access to my bank without credentials, even if I choose, for my convenience, to save my bank login credentials in my browser settings (which is a bad idea - a big risk for a small convenience).
Returning to the original question
Again, there is a little lack of clarity. There are different levels of login:
- to the Lubuntu system
- to the (presumably) secured wifi access point
- to the server hosting the router (firewall or intranet server) which may or may not exist in "mercmanager2's" situation
- and finally to a web server on the internet somewhere
The latter is ALWAYS handled in the browser, not the OS, whether you use Lubuntu or Microsoft or MacOS.
The way the question is worded, I'll suppose there is a firewall server. It appears "mercmanager2" wishes to authenticate each internet user on a shared machine individually to the firewall. An example would be a public library, where different users log in through the same wifi access point, but have to provide personal credentials (a library card number) to access the internet.
If the logins are being passed through, this is something you can NOT correct on your local machine, be it Linux, Windows, or Mac. This is something being handled at the firewall. At my library, my personal machine gets a lease, associated with my machine's MAC address (a number identifying my wifi hardware). When I change users on my machine, the lease on the server is still valid, so I am passed through.
In contrast, the library's public machines enforce authentication. The lease is canceled when a user logs out and a new lease is issued when a new user logs on. This is done on the firewall, not the public machine. This is the same, whether the firewall uses MacOS, Windows, or Linux.
If that is not the issue, then I can't make sense of the original question.
