When I print a website to PDF, the file name saves with a weird box-symbol  with F022 inside. Anyone know why? I'm new to Ubuntu, and not sure if this is a problem with my system, maybe I installed something wrong, not sure....
After Googling, I found it toward the middle of this webpage:
http://www.fileformat.info/info/unicode/char/f022/index.htm
The following is from the website:
string.toUpperCase() 
string.toLowerCase() 
Someone else posted a similar issue 2years ago on this tread: Text inside files has squares with numbers in it but they were getting it due to OCR it sounds like. In anycase HP M......
That symbol represent no other thing but a unicode character. Basically, it displays that kind of characters (the ones with hexadecimal numbers inside a square) when the particular character is not supported by the font you're currently using.
You can check, if you've got a font which is able to display it, in the following link: http://www.fileformat.info/info/unicode/char/f022/browsertest.htm
And here they are the fonts which support that character: http://www.fileformat.info/info/unicode/char/f022/fontsupport.htm
I doesn't look like is a particular issue of your system or of your installation. I neither can to display that character.
Greetings.
Akronix
  • 1,223
