I have prepared a PXE-preseed-netinstall configuration for a cluster I am setting up. On all nodes, the install process works perfectly. But I have one node for which the installer freeze when installing the base system. I suspect a failure on disk (it is a hardware RAID, in fact).
Is there a way to store the logs of the install? This could maybe help to understand what is going on on that node...
Jorge Castro
  • 73,717
Danduk82
  • 163
The installer logs to /var/log/installer
I believe the mini.iso uses the debian-installer: See this page for more info on debugging the installer:
LiveWireBT
  • 29,597
Jorge Castro
  • 73,717
