When I go to visit this url
https://github.com/search?q=jquery+stars%3A>10+forks%3A<10&type=Repositories
using this command for lynx:
lynx -accept_all_cookies https://github.com/search?q=jquery+stars%3A>10+forks%3A<10&type=Repositories
First I get a code like this -> [1] 4324 then another line which says -> bash: 10: No such file or directory
So, question is how can I browse this url url lynx? Also I can not curl this url , curl also showing nearly like same.
I am using ubuntu 12.04 LTS
Bash is interpreting the URL. The < and & mean things to it so they're being ripped around and aren't being passed to lynx.
The simple answer is to quote the url:
lynx -accept_all_cookies 'https://github.com/search?q=jquery+stars%3A>10+forks%3A<10&type=Repositories'
I'm using single quotes here so that even $ isn't interpreted.
Oli
  • 299,380
The problem is that your URL contains special characters that are being interpreted by the shell because you are not quoting it. So, short answer, use quotes:
Long answer: The specific issues here are >10 and &. The & sends a job to the background:
$ sleep 5 &
[1] 2015
Note that the above causes a similar message to appear, the number in brackets is the job ID, in this case 1 since it is the only job running in the background and the other number is the process ID (PID) of the backgrounded process.
The next issue is the <10 which means "read input from the file called '10' and >10 which the shell interprets as "redirect output to a file called '10'`. For example:
$ echo "Hello" > 10
$ cat 10
Hello
All of these issues can be avoided if you simply quote such things, quoting will protect special characters from being interpreted by the shell.
terdon
  • 104,119
