I'm working with ec2 instances and was trying to execute a ruby script on another instance after ssh to that instance. I have a ruby script which updates configuration files, so i need to run that script as super user. when i run the script manually on that instance, sudo ruby recreate-532d01c.rb, the error that comes is
sudo: ruby: command not found
Running simple scripts with no root permissions works, eg.ruby file_1.rb.
Using rvmsudo in place of sudo executes the script with warning,
ubuntu@ip-10-0-0-111:~$ rvmsudo ruby recreate-82bb000012.rb
Warning: can not check `/etc/sudoers` for `secure_path`, falling back to call via `/usr/bin/env`, this breaks rules from `/etc/sudoers`. Run:
    export rvmsudo_secure_path=1
to avoid the warning, put it in shell initialization file to make it persistent.
In case there is no `secure_path` in `/etc/sudoers`. Run:
    export rvmsudo_secure_path=0
I tried to execute the below command from rails console of one of the instance to test and it fails to recognize ruby as command
1.9.3-p545 :002 > system("ssh -i /home/ubuntu/.ssh/own_key.pem ubuntu@**.***.***.** ruby execute-52d.rb")
bash: ruby: command not found
I tried with possible solutions over web, but could not resolve the issue. I have the same configuration running for one of my old aws acount, this is a newly created account. Not sure if this could be issue in any way as currently ec2 instances fall under vpc by default and have some changes after dec 2013
Bijendra
  • 850
The error you are getting indicates that ruby is not in the sudo $PATH. TO get around this, you either need to export your environment correctly:
sudo -E ruby
Or, just use the full path. Run type ruby as your regular user, and use that with sudo. For example:
$ type ruby
ruby is /usr/bin/ruby
$ sudo /usr/bin/ruby
terdon
  • 104,119
