24
I have been having the exact same problem as described in this post and someone in the answers suggested that you upgrade to opencv version 2.9. I was wondering how do that? I installed the version I have now by doing
sudo apt-get install python-opencv
Also, how can I check what version I'm running now? I'm on Ubuntu 13.10
EDIT:
After girardengo answer I know I'm on version 2.4.5 Thank you for that!
Avinash Raj
  • 80,446
evan54
  • 745
Before installing the development version of OpenCV, I'd suggest to use this code to set the capture size (from the link you posted I assume you're using python):
import cv2
cap = cv2.VideoCapture(device_no)
cap.set(cv2.cv.CV_CAP_PROP_FRAME_WIDTH, width)
cap.set(cv2.cv.CV_CAP_PROP_FRAME_HEIGHT, height)
To install the development version of opencv (3.0.0-dev today) please follow the steps below:
cd $HOME
mkdir opencv_src
cd opencv_src/
git clone https://github.com/Itseez/opencv.git
cd opencv/
mkdir release
cd release/
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
make
sudo make install
Open terminal, then launch python interpeter:
python
then, import opencv:
import cv2
finally, print version:
cv2.__version__
if you want to install the latest development version of opencv, you can follow the instructions of the official documentation of opencv from here
girardengo
  • 5,005
Script is mentioned below, copy it and run it
sudo bash install_opencv.sh
Here is script...
# KEEP UBUNTU OR DEBIAN UP TO DATE
 sudo apt-get -y update
 sudo apt-get -y upgrade
 sudo apt-get -y dist-upgrade
 sudo apt-get -y autoremove
 #INSTALL THE DEPENDENCIES
 # Build tools:
 sudo apt-get install -y build-essential cmake
 # GUI:
 sudo apt-get install -y qt5-default libvtk6-dev
 # Media I/O:
 sudo apt-get install -y zlib1g-dev libjpeg-dev libwebp-dev libpng-
 dev libtiff5-dev libjasper-dev libopenexr-dev libgdal-dev
 # Video I/O:
 sudo apt-get install -y libdc1394-22-dev libavcodec-dev libavformat-
 dev libswscale-dev libtheora-dev libvorbis-dev libxvidcore-dev
 libx264-dev yasm libopencore-amrnb-dev libopencore-amrwb-dev libv4l-
 dev libxine2-dev
 # Parallelism and linear algebra libraries:
 sudo apt-get install -y libtbb-dev libeigen3-dev
 # Python:
 sudo apt-get install -y python-dev python-tk python-numpy python3-
 dev python3-tk python3-numpy
 # Java:
 sudo apt-get install -y ant default-jdk
 # Documentation:
 sudo apt-get install -y doxygen
 # INSTALL THE LIBRARY (YOU CAN CHANGE '3.0.0' FOR THE LAST STABLE
 VERSION)
 sudo apt-get install -y unzip wget
 wget https://github.com/Itseez/opencv/archive/3.1.0.zip
 unzip 3.1.0.zip
 rm 3.1.0.zip
 mv opencv-3.1.0 OpenCV1
 cd OpenCV1
 mkdir build
 cd build
 cmake -DWITH_QT=ON -DWITH_OPENGL=ON -DFORCE_VTK=ON -DWITH_TBB=ON -
 DWITH_GDAL=ON -DWITH_XINE=ON -DBUILD_EXAMPLES=ON ..
 make -j4
 sudo make install
 sudo ldconfig
 # EXECUTE SOME OPENCV EXAMPLES AND COMPILE A DEMONSTRATION
 # To complete this step, please visit
 'http://milq.github.io/install-opencv-ubuntu-debian'.
