No success mounting a device in read-write mode. After plugging it in, it is mounted.
$ sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
NAME   FSTYPE    SIZE MOUNTPOINT         LABEL
sda            238,5G
├─sda1 ext4    230,6G /
├─sda2             1K
└─sda5 swap      7,9G [SWAP]
sdb            931,5G
├─sdb1 vfat      200M                    EFI
└─sdb2 hfsplus 931,2G /media/cr/FinnHard FinnHard
sr0             1024M
$ sudo mount -o remount,rw  '/media/cr/FinnHard'
mount: /media/cr/FinnHard not mounted or bad option
$ sudo umount /media/cr/FinnHard
$ sudo mount -t hfsplus -o rw  /dev/sdb2 '/media/FinnHard'
mount: warning: /media/FinnHard seems to be mounted read-only.
What am I doing wrong?
Christian
  • 312
  • 19
It looks like you're running into the problem described here. You should be able to mount that volume read/write by running:
sudo apt-get install hfsprogs
sudo mount -t hfsplus -o remount,force,rw /media/cr/FinnHard
You'll be able to mount it again later on using:
sudo mount -t hfsplus -o force,rw /dev/sdb2 /media/cr/FinnHard
jkt123
  • 3,600
