34
I installed many packages from many PPAs on my system. I want to list all the installed packages which are installed from launchpad PPAs, not repositories.
Is this possible through command-line?
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Avinash Raj
  • 80,446
6 Answers6
32
The following command returns the package name and its ppa (if installed from a ppa):
apt-cache policy $(dpkg --get-selections | grep -v deinstall$ | awk '{ print $1 }') | perl -e '@a = <>; $a=join("", @a); $a =~ s/\n(\S)/\n\n$1/g;  @packages = split("\n\n", $a); foreach $p (@packages) {print "$1: $2\n" if $p =~ /^(.*?):.*?500 http:\/\/ppa\.launchpad\.net\/(.*?)\s/s}'
Details:
  • dpkg --get-selections gives only the installed packages after grep -v deinstall$
  • awk '{ print $1 }' returns only the package name
  • perl -e '@a = <>; $a=join("", @a)' concatenates all the lines returned by apt-cache policy
  • $a =~ s/\n(\S)/\n\n$1/g; adds a newline between each package section
  • @packages = split("\n\n", $a); is a perl array containing all the packages infos, one package per item.
  • foreach $p (@packages) {print "$1: $2\n" if $p =~ /^(.*?):.*?500 http:\/\/ppa\.launchpad\.net\/(.*?)\s/s} is a loop where the package and the ppa are printed if a ppa with prio 500 is found in the policy.
15
Some legacy tools like aptitude have very useful search feature. synaptic (GUI) too has filter by Origin feature (Already listed as another answer here).
user.dz
  • 49,176
The source of an installed package can be checked using apt-cache, for example
$ apt-cache policy oracle-java7-installer
oracle-java7-installer:
  Installed: 7u51-0~webupd8~7
  Candidate: 7u51-0~webupd8~7
  Version table:
 *** 7u51-0~webupd8~7 0
        500 http://ppa.launchpad.net/webupd8team/java/ubuntu/ precise/main i386 Packages
        100 /var/lib/dpkg/status
The output of apt-cache policy <package_name> contains the source.
One can use the following script to obtain the list of packages installed from PPAs.
#!/bin/bash
echo "List of packages which are not installed from Ubuntu repository"
for i in `dpkg -l | grep "^ii" | awk '{print $2}'`
do
    j=`apt-cache policy "$i" | grep "ppa.launchpad.net"`
    if [ $? -eq 0 ]; then
        echo "$i"
        #echo "$i $j"
    fi
done
sourav c.
  • 46,120
Install synaptic. You can then browse packages by "origin" or even any other custom filter.
In accordance with this answer and this post, you can get a list of all packages from all the PPAs installed on your system using the following bash code:
for APT in $(find /etc/apt/ -name \*.list); do
  grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do
    USER=$(echo $ENTRY | cut -d/ -f4)
    PPA=$(echo $ENTRY | cut -d/ -f5)
    awk '$1 == "Package:" { if (a[$2]++ == 0) print $2; }' /var/lib/apt/lists/*$USER*$PPA*Packages
    done
done
And in accordance with this answer, you can get a list of all installed packages in your system using:
dpkg --get-selections | grep -v deinstall | cut -f1
Now, let's join these two ideas to get a list of all the packages which are installed from PPAs:
(for APT in $(find /etc/apt/ -name \*.list); do
    done
done; dpkg --get-selections | grep -v deinstall | cut -f1) | sort | awk 'dup[$0]++ == 1'
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
I wanted to know how many packages I had from each ppa, so I slightly modified Sylvain's awesome answer:
apt-cache policy $(dpkg --get-selections | grep -v deinstall$ | awk '{ print $1 }') \
| perl -e '@a = <>; $a=join("", @a); $a =~ s/\n(\S)/\n\n$1/g;  @packages = split("\n\n", $a); foreach $p (@packages) {printf "%-40s %s\n", $2, $1 if $p =~ /^(.*?):.*?500 http:\/\/ppa\.launchpad\.net\/(.*?)\s/s}' \
| sort \
| uniq -c -w 40
by printing ppa first and using only first 40 characters to count & deduplicate with uniq, I can get this kind of output:
  5 alexlarsson/flatpak/ubuntu               flatpak
147 bleedingedge/focal-bleed/ubuntu          bzip2
  1 justinabrahms/ttf-cascadia-code/ubuntu   ttf-cascadia-code
 44 libreoffice/ppa/ubuntu                   fonts-opensymbol
 71 savoury1/backports/ubuntu                bash
 41 savoury1/multimedia/ubuntu               dav1d
  8 strukturag/libheif/ubuntu                aom-tools
 12 ubuntugis/ubuntugis-unstable/ubuntu      gdal-bin
eddygeek
  • 1,839
