Haskell-platform currently has unmet dependencies on Ubuntu 11.04. This is a known bug, but I'd like to get it installed sooner rather than later.
Can anyone recommend a way to install haskell-platform on 11.04? The bug report that I linked to offers a solution that requires editing a binary package (?) using vim, but I'd rather install something from source than go that route.
Jorge Castro
  • 73,717
j1mc
  • 593
6 Answers6
This bug has now been fixed and is in 11.04 -proposed. Therefor you can enable proposed packages and install haskell-platform. If you do not want to keep getting -proposed updates you can disable it once you have haskell-platform installed. Look here for a guide on how to enable -proposed updates.
This bug is fixed in 11.10.
I am afraid you are out of options for the moment besides compiling it yourself (but editing the package seems alot less problematic).
Either you edit var/cache/apt/pkgcache.bin as shown at comment #12 in the bug or you will have to wait until all the problems have been ironed out for using the Haskell platform on Ubuntu 11.04
I would go with editing the package. It is not that difficult and I expect you to be able to do that without any problem.
edit: now I am on my own machine.
cd /var/cache/apt/
sudo cp pkgcache.bin pkgcache.backup.bin
sudo cp pkgcache.bin pkgcache.test.bin
sudo vi pkgcache.test.bin
enter
/6.12.1+
This will result in:
009fe21547b0cc8fc2f7ee1ec74d3e27^@haskell-http-doc^@1:2^@libghc6-http-
doc^@^@009fe21547b0cc8fc2f7ee1ec74d3e27^@2.7.0-
2^@xemacs22^@^@b8b7ecd2f37fbc271d0108a704c42056^@haskell-pcre-light-doc^@1:2^@libghc6-
pcre-light-doc^@^@009fe21547b0cc8fc2f7ee1ec74d3e27^@haskell-
platform^@2010.1.0.0.1^@6.12.1^@6.12.1+^@libghc6-cgi-dev^
See the 6.12.1 at the bottom?
Navigate with the arrow keys to the 1 of .1+ When on the 1 hit r 4 :wq!
That's the practise run. Remove the .test from the sudo vi pkgcache.test.bin to change the real file. After that install it in the normal way.
Rinzwind
  • 309,379
Try compiling it from source - http://hackage.haskell.org/platform/linux.html
You can install it from the following PPA: https://launchpad.net/~brcha/+archive/ppa
Here's how:
sudo add-apt-repository ppa:brcha/ppa
sudo apt-get install haskell-platform
Voila!
Did you checked this out? http://sporkcode.wordpress.com/2009/07/11/installing-the-haskell-platform-in-ubuntu/
If you are using 64bit UBUNTU please check comments to resolve some problems ;)
I'm running a small Haskell course right now and I've created Natty Live CDs for the course participants. What I've done is add all the packages I needed(and which would go with the platform anyway) without the haskell-platform package. Everything else I needed, I installed with cabal-install.
This may not be the perfect solution but it works for me.
Shipping a broken package was very lame.
Hope this helps.
mhmhmhmh
  • 1,598
