How can I get around the dependency problem when installing libssl-dev?
The problem:
$ sudo apt-get install libssl-dev
Reading package lists... Done
Building dependency tree
 libssl-dev : Depends: libssl1.0.0 (= 1.0.1c-4ubuntu8) but 1.0.1c-4ubuntu8.1 is to be installed
System info:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 13.04
Release:    13.04
Codename:   raring
$ uname -a
Linux Compy 3.8.0-30-generic #44-Ubuntu SMP Thu Aug 22 20:52:24 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
My question looks similar to this one - but no, apt-get update does not do a thing for me.
bguiz
  • 512
Solution is to ensure that the software sources includes updates, like so:
$ sudo vi /etc/apt/sources.list
$ #add the following two lines to sources.list for raring-updates
 deb http://ch.archive.ubuntu.com/ubuntu/ raring main restricted
 deb-src http://ch.archive.ubuntu.com/ubuntu/ raring main restricted
+deb http://ch.archive.ubuntu.com/ubuntu/ raring-updates main restricted
+deb-src http://ch.archive.ubuntu.com/ubuntu/ raring-updates main restricted
$ sudo apt-get update
$ apt-cache policy libssl-dev
You should see output that includes raring-updates
Should work this time!
bguiz
  • 512
