Nautilus exits when I try to access a certain folder. This is what it says when started from the command line:
user@Computer:~/Dokumente/Briefe$ nautilus ./
Initializing Arronax v0.05...
sys:1: Warning: g_object_set: assertion 'G_IS_OBJECT (object)' failed
Syntax Warning: May not be a PDF file (continuing anyway)
Syntax Error: Couldn't find trailer dictionary
Syntax Error: Couldn't read xref table
Error loading document: File type Einfaches Textdokument (text/plain) is not supported
sys:1: Warning: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Speicherzugriffsfehler (Speicherabzug geschrieben)
I'm on ubuntu 13.10 with gnome-shell classic. I followed some advice from other posts, e.g. removed ubuntu one, ran sudo apt-get purge nautilus-open-terminal and restarted the computer, but the error remains.
