Recently after force shutting down during a long Shutdown then when it started up it would go to grub and then it would flash a login screen before going black with a not moving terminal cursor. After searching for a result I saw a solution to a similar problem which was to change the boot code in grub from quiet splash to Nomodset and when I tried that it worked for a while but now I have to constantly change the boot code and its a random chance if it works, no pattern showing. Can anyone help me?
Asked
Active
Viewed 125 times
you must boot your Ubuntu from a live cd or a live USB stick and choose the option Try Ubuntu.
open a terminal and type( or just copy paste) this following command
sudo add-apt-repository -y ppa:yannubuntu/boot-repair && sudo apt-get update
hit ENTER
then type this command also
sudo apt-get install -y boot-repair && boot-repair
after installing boot repair choose recommended repair.
then reboot your computer and all must work like charm.
hannibal
- 101
