When I try to install bison on my ubuntu 14.04 using the command sudo apt-get install bison, the version 3 is installed.
I would like to downgrade bison to use the version 2.7.
How can I do it?
Thanks.
I installed last pkgs of bison (2.7.1) and libbison-dev (2.7.1) from Saucy and it worked like a charm.
wget http://launchpadlibrarian.net/140087283/libbison-dev_2.7.1.dfsg-1_amd64.deb
wget http://launchpadlibrarian.net/140087282/bison_2.7.1.dfsg-1_amd64.deb
dpkg -i libbison-dev_2.7.1.dfsg-1_amd64.deb
dpkg -i bison_2.7.1.dfsg-1_amd64.deb
To prevent update manager from overwriting this package
apt-mark hold libbison-dev
apt-mark hold bison
Done.
Just give the package version also as follows:
apt-get install pkg=version
and you can get all the available versions using apt-cache showpkg bison
You can install bison version 2.7 via linuxbrew. Once you have installed linuxbrew by:
ruby -e "$(wget -O- https://raw.github.com/Homebrew/linuxbrew/go/install)"
and adding the following to the bottom of .bashrc or .zshrc:
export PATH="$HOME/.linuxbrew/bin:$PATH"
export LD_LIBRARY_PATH="$HOME/.linuxbrew/lib:$LD_LIBRARY_PATH"
You can install Bison 2.7!
brew install bison27
Homebrew is meant for macs, so it will yell at you for not using your Mac properly if you run brew doctor. As Macs already have Bison installed, it will refuse to finish the install. You can safely force it by doing:
brew link bison27 --force
And now check bison -V to see you are using Bison 2.7!
