Im trying to excute the minecraft.jar. Ive tried to run several commands but always coming back with "unable to access jarfile"
My file is stored on my downloads and I am the owner it says on file properties. Any ideas? Thanks!
have you tried to run this command?
java -jar minecraft.jar
othwise make it executable like this :
chmod +x /path/to/your/minecraft.jar
and than run it ./minecraft.jar
also check : Security/ExecutableBit
Finally, a question I can answer! Right click the .jar file and select properties. Go to permissions and click the box at the bottom 'Allow executing file as program'. Close the window. Open Ubuntu software centre. Search for Java 7. Install the package 'OpenJDK Java 7 Runtime' Once installed, open the minecraft.jar file and it should work. If not right click it, select 'open with...' and select Java 7 Runtime. Thats it!
Tell me if it worked.
