I found this thread:
https://askubuntu.com/questions/439901/how-do-i-install-a-d-link-dwa-131
But it has been closed. One comment referred to this guide:
http://bernaerts.dyndns.org/linux/74-ubuntu/277-ubuntu-precise-dwa-131-rev-b1
But it doesn't work.
To begin, the guide is for this:
package barcode showing H/W Ver.:B1 F/W Ver.:2.00
But my package has
package barcode showing H/W Ver.:B1 F/W Ver.:2.01
As for the vendor ID of
2001 and Device ID 330d
I can't see either of those numbers on the box or in the example shown in the guide.
Next, the guide talks about updating the kernel but the kernel I am running is already higher:
My kernel
Linux connor 3.11.0-19-generic #33-Ubuntu SMP Tue Mar 11 18:48:34 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
My version
connor@connor:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 13.10
Release:    13.10
Codename:   saucy
When I do the next step sudo modprobe rtl8192cu swenc=1 there's no output
Then the next echo "2001 330D" | sudo tee /sys/bus/usb/drivers/rtl8192cu/new_id this is the output
2001 330D
My lsusb
Bus 003 Device 006: ID 2001:330d D-Link Corp.
I've also been trying this thread
http://ubuntuforums.org/showthread.php?t=2200493&page=2&p=12978483#post12978483
I did the driver update instruction, it seemed to update but when I reboot still no light coming on the USB device
Next I try this command
lsmod
iwconfig
ifconfig -a
cat /etc/resolv.conf
This is the output
Module                  Size  Used by
rfcomm                 69130  0
crct10dif_pclmul       14289  0
crc32_pclmul           13113  0
lrw                    13286  1 aesni_intel
gf128mul               14951  1 lrw
ath9k                 155907  0
ath9k_common           13859  1 ath9k
ath9k_hw              444732  2 ath9k_common,ath9k
ath                    23827  3 ath9k_common,ath9k,ath9k_hw
mac80211              597268  1 ath9k
cfg80211              480503  3 ath,ath9k,mac80211
connor@connor:~$ iwconfig
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=16 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
connor@connor:~$ ifconfig -a
wlan0     Link encap:Ethernet  HWaddr 24:fd:52:79:9c:53
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
Does anyone know how to get this device working?
Update:
lsusb output, with/without USB modem attached (difference only)
connor@connor:~$ lsusb
Bus 003 Device 013: ID 2001:330d D-Link Corp.
dmesg output, last 20 lines
ConnorJ
  • 73
Am on 14.04 with same DWA131-B1 adapter, used this driver (follow instructions there) and added 8192cu to /etc/modules and
to /etc/rc.local (note that this still uses the 'rtl') as per this so far stable and fast without swenc=1
Volker Siegel
  • 13,295
nzidol
Prerequisites:
sudo apt-get install linux-firmware-nonfree
Output from, that changes with/without the USB modem inserted.
lsusb
eg. (as you have already supplied)
Try the following
dmesg
sudo rfkill unblock all
dmesg
What you are looking for is: What (if anything) was added to the dmesg output, after the driver (rtl8182cu) was loaded to memory.
david6
  • 14,528
  • 38
  • 46
The default kernel driver is weak and gets a range of maybe 2-5 meters with a clear line of sight to the AP.
I have this card and it works great when you use the newer firmware from realtek. The original new firmware won't build properly on kernels >=3.10 however, patched versions are available from github.
Here are the instructions:
12.04 & 14.04+: you can view these instructions or just do as I say.
(use these instructions when your wireless USB device [rtl8192cu] is not automatically recognized by Ubuntu)
echo "rtl8192cu" | sudo tee -a /etc/modules
Then, edit /etc/rc.local by opening the file with your favorite text editor like in this example:
sudo gedit /etc/rc.local
make sure it says . . .
echo "2001 330D" | tee /sys/bus/usb/drivers/rtl8192cu/new_id
exit 0
You can use the wireless now or, alternatively, you can make sure you have all of your work saved before you type:
sudo reboot
Your wireless driver should start up automatically.
To compile and install the proprietary Realtek 8192cu driver, run the following commands in an open terminal:
sudo apt-get update && sudo apt-get install git build-essential linux-headers-generic dkms
git clone https://github.com/dz0ny/rt8192cu.git --depth 1
cd rt8192cu
sudo make dkms
For hard installation use:
make
sudo make install
instead of sudo make dkms .
To enable this driver, use the command:
sudo modprobe 8192cu
Finally, update /etc/modules with this command before you reboot:
echo '8192cu' | sudo tee -a /etc/modules
Souce #1: bernaerts.dyndns.org
Source #2: github.com/dz0ny
mchid
  • 44,904
  • 102
  • 162
Try this - https://github.com/Mange/rtl8192eu-linux-driver
git clone https://github.com/Mange/rtl8192eu-linux-driver.git
cd rtl8192eu-linux-driver
sudo make
sudo make install
timmson
  • 86
