22
I want to use Guake at right monitor.
So I added this ppa by sudo add-apt-repository ppa:cberner/guake, and sudo apt-get update.
https://launchpad.net/~cberner/+archive/guake/+index?field.series_filter=raring
Instruction says that I can set monitor_index somehow. But I couldn't find how to configure.
Does someone know about this?
ironsand
  • 1,167
10 Answers10
21
I use two monitors and wanted Guake to be displayed on the right one (where by default it is displayed on the left one).
What I did was to edit my /usr/bin/guake/ file replacing the get_final_window_rect method with this:
def get_final_window_rect(self):
    """Gets the final size of the main window of guake. The height
    is the window_height property, width is window_width and the
    horizontal alignment is given by window_alignment.
    screen = self.window.get_screen()
    height = self.client.get_int(KEY('/general/window_height'))
    width = 100
    halignment = self.client.get_int(KEY('/general/window_halignment'))
    # get the rectangle just from the first/default monitor in the
    # future we might create a field to select which monitor you
    # wanna use
    monitor = 1 # use the right most monitor
    window_rect = screen.get_monitor_geometry(monitor)
    # see if we don't have another screen, and if so, use the first one
    if window_rect.width == 0:
        monitor = 0
    total_width = window_rect.width
    window_rect.height = window_rect.height * height / 100
    window_rect.width = window_rect.width * width / 100
    if width < total_width:
        if halignment == ALIGN_CENTER:
            window_rect.x = (total_width - window_rect.width) / 2
            if monitor == 1:
                    right_window_rect = screen.get_monitor_geometry(0)
                    window_rect.x += right_window_rect.width
        elif halignment == ALIGN_LEFT:
            window_rect.x = 0
        elif halignment == ALIGN_RIGHT:
            window_rect.x = total_width - window_rect.width
    window_rect.y = 0
    return window_rect
Basically, it uses 1 as the monitor index and later on, adds the right screen width to the start point display of the guake window
hope this helps!
wilfo
  • 321
Good news!
On version 0.8.5, Guake will be displayed on the active monitor, so you don't have to tweak the Guake code anymore.
The solution is very simple, as you want to align your Guake screen to your right hand side monitor so in starting position (x, y) of screen, y co-ordinate is going to be same i.e. it will start from 0 but x coordinate will change and it should be equal to width of you left side monitor. To be able to do this you need to do 2 things.
I. Change monitor number to 1, as suggested above. In line
Replace 0 by 1.
II. Add first screen width in x position of starting co-ordinate. to do this.
Replace
        window_rect.x = 0
window_rect.y = 0
return window_rect
By
         window_rect.x += (total_width - window_rect.width) / 2
         window_rect.x += 0
         window_rect.x += total_width - window_rect.width
window_rect.y = 0
return window_rect
Once you do these changes and restart guake (Quit and start again), You should get the desired alignment of Guake screen.
Hope this helps :)
lalit
  • 121
I also made this a question: guake at right side monitor in dual display environment - Ubuntu 15.10(Wily Werewolf))
In Ubuntu 15.10 guake has changed a little bit. To change your terminal to the right monitor you have to edit:
sudo vim /usr/lib/python2.7/dist-packages/guake/guake_app.py
then change in line 831:
by:
window_rect = screen.get_monitor_geometry(1)
kill and restart guake
Anyone knows a way to do this less hacky?
clvx
  • 201
As lalit said, the best way I found to do this on ubuntu 14.04LTS was changing
to
but changing
        window_rect.x = 0
window_rect.y = 0
return window_rect
to
         window_rect.x += total_width + (total_width - window_rect.width) / 2
         window_rect.x += 0
window_rect.y = 0
return window_rect
The only difference its in the first "if", without adding "total_width" to "window_rect.x" guake appears in the middle of my left monitor.
P.S: Sorry Lalit but I cannot add a comment to your post since I have no points yet =(
The solution by wilfo doesn't work to me. In my case i solved on Linux Mint with the following code:
    width = 100
    # wanna use
    #monitor = 0 # use the left most monitor
    monitor = screen.get_n_monitors() - 1 # use the right most monitor
    monitor_rect = screen.get_monitor_geometry(monitor)
    window_rect = monitor_rect.copy()
    if width < monitor_rect.width:
            window_rect.x = monitor_rect.x + (monitor_rect.width - window_rect.width) / 2
            window_rect.x = monitor_rect.x + monitor_rect.width - window_rect.width
    window_rect.y = monitor_rect.y
    return window_rect
I take it from here, but i changed 80 to 100.
I haven't tested this but I think you can just edit /usr/bin/guake since it is a python script.
Find
window_rect = screen.get_monitor_geometry(0) #line 824 on my machine
and change the 0 to the index of the monitor you want guake to display in.
colboynik
  • 756
Just to add to smartmouse and wilfo's answers, once you make the change to /usr/bin/guake you then have to to a hard restart. Logging out of the guake session does not end the Guake process.
Open system monitor and kill the guake application process then restart
I had to change this on Ubuntu 16.04 LTS with 2 monitors.
I was trying the above methods but realized the code had changed since. I went into ~/.gconf/apps/guake/general and edited %gconf.xml and changed display_n (int) from 0 to 1 for my 2nd monitor.
Hope this helps :)
Anwar
  • 77,855
-1
I try in Ubuntu 14.04, I found you just need to click "Preferences" at guake icon (right top screen) in either monitor, then click "Show" in the same monitor, then you can see guake terminal pop out at the monitor you are using !!!
