when trying to run my Laptop after suspend .
I have a black screen and nothing work. keyboard,mouse,touch bad .
My PC : Laptop Dell Inspiron 15 R
Ram :4 GB
graphic Card :Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A]
any help
Ahmed
Actually there is a bug which you can find in Launchpad.net
Best thing is that there is also a patch through which you can solve this issue.
Follow these steps hope it works for you also:
Open terminal and execute these steps:
1 - Backup old settings
sudo cp /etc/default/grub /etc/default/grub_back
2 - Open file to edit
sudo gedit /etc/default/grub
3 - Replace the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to the line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pcie_aspm=force"
4 - Save the file Ctrl+S and close Ctrl+Q
Note: The next line to the line mentioned above should be GRUB_CMDLINE_LINUX="" not GRUB_CMDLINE_LINUX="acpi_osi=Linux"
5 - Now execute following command to update the grub
sudo update-grub
Re-start your system once.
Note: If you have trouble in brightness also and above method doesn't fix it then you can test by adding these lines in place I mentioned above.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
or
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor pcie_aspm=force"
or
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
or
GRUB_CMDLINE_LINUX_DEFAULT="pcie_aspm=force"
or
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pci=nomsi"
Note: You have to do a sudo update-grub and a system restart every time you change the grub file
Different system would need different options, if any of the option works, I request to mention that in the comment.
6 - Edit/create the file
gksudo gedit /etc/pm/sleep.d/01_switchvt
7 - copy and paste this code and save
#!/bin/sh
# Switch to a VC before suspending and back after resume
case "$1" in
        resume|thaw)
            chvt 7
        suspend|hibernate)
            chvt 1
esac
8 - make it executable:
chmod 755 /etc/pm/sleep.d/01_switchvt
sources: https://askubuntu.com/a/387676/265172 and https://askubuntu.com/a/361706/265172
