I have a 52 u rack with multiple Cisco switches and routers. I also have an Ubuntu server with kvm installed. I created a vm with Ubuntu 12.04 installed for use as a tftp server to transport images between it and my networking equipment. I installed tftp-hpa, tftpd-hpa and xinetd on it per various guides on this site and others.
After much pain and frustration, I was able to tftp locally on the host and from my windows machine. The thing is I have to create empty files for each file I want to upload to the server under the "nobody" user in the /var/lib/tftpboot directory using the following command:
sudo -u nobody sh <<< "cd /var/lib/tftpboot; touch filename; chmod 777 filename"
BOTTOM LINE UP FRONT: I want to simply be able to "tftp put" any file I want without having to use the command above to create a file first. Please help me before I start breaking expensive things! Here is my xinetd.d tftp config:
service tftp
disable = no
socket_type = dgram
wait = yes
user = root
server = /usr/sbin/in.tftpd
server_args = -v -s /var/lib/tftpboot
