Before asking i have checked Virtualbox Kernel driver not installed and VirtualBox '/etc/init.d/vboxdrv setup' issue, i have exactly same issue and have reinstalled VB also,
output of running sudo dpkg-reconfigure virtualbox-dkms is shown below :
Deleting module version: 4.1.12 completely from the DKMS tree.
Done. Loading new virtualbox-4.1.12 DKMS files... Building only for 3.5.0-47-generic Building initial module for 3.5.0-47-generic
Error! Bad return status for module build on kernel: 3.5.0-47-generic (i686)
Consult /var/lib/dkms/virtualbox/4.1.12/build/make.log for more information.
make.log
DKMS make.log for virtualbox-4.1.12 for kernel 3.5.0-47-generic (i686) Thu Apr 3 21:37:08 IST 2014 make: Entering directory /usr/src/linux-headers-3.5.0-47-generic' LD
/var/lib/dkms/virtualbox/4.1.12/build/built-in.o LD
/var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/built-in.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/linux/SUPDrv-linux.o
CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/SUPDrv.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/SUPDrvSem.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/alloc-r0drv.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/initterm-r0drv.o
CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/memobj-r0drv.o
CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/mpnotification-r0drv.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/powernotification-r0drv.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/assert-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/alloc-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/initterm-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/memobj-r0drv-linux.o /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/memobj-r0drv-linux.c: In function ‘rtR0MemObjLinuxDoMmap’: /var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/memobj-r0drv-linux.c:1150:9: error: implicit declaration of function ‘do_mmap’ [-Werror=implicit-function-declaration] cc1: some warnings being treated as errors make[2]: *** [/var/lib/dkms/virtualbox/4.1.12/build/vboxdrv/r0drv/linux/memobj-r0drv-linux.o] Error 1 make[1]: *** [/var/lib/dkms/virtualbox/4.1.12/build/vboxdrv] Error 2 make: *** [_module_/var/lib/dkms/virtualbox/4.1.12/build] Error 2 make: Leaving directory
If someone has faced same situation...please help me out!!
Since no helpful answer is found, here is what helped me... :
uninstall the exisiting VB :
  sudo apt-get purge virtualbox
Dependency
First install the dependency package to avoid error.**
sudo apt-get install dkms
To add PPA
Open a terminal and run the following command to download and install the key from Oracle. Issue the password for the user when prompted.
wget -q http://download.virtualbox.org/virtualbox/debian/oracle_vbox.asc -O- | sudo apt-key add -
After installing the Oracle public key, use the below command to add it to your repository.
For Ubuntu 13.10
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian saucy contrib" >> /etc/apt/sources.list.d/virtualbox.list'
For Ubuntu 13.04
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian raring contrib" >> /etc/apt/sources.list.d/virtualbox.list'
For Ubuntu 12.10
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian quantal contrib" >> /etc/apt/sources.list.d/virtualbox.list'
For Ubuntu 12.04
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian precise contrib" >> /etc/apt/sources.list.d/virtualbox.list'
For Ubuntu 11.10
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian oneiric contrib" >> /etc/apt/sources.list.d/virtualbox.list'
For Ubuntu 11.04
sudo sh -c 'echo "deb http://download.virtualbox.org/virtualbox/debian natty contrib" >> /etc/apt/sources.list.d/virtualbox.list'
Once you added the repo using the above command,
Update your repository.
sudo apt-get update
To Install
Now install the virtualbox 4.3 using the below command.
sudo apt-get install virtualbox-4.3
To install the previous version just replace 4.3 to 4.2 / 4.1 / 4.0 / 3.2 in the above command.
To Open
Go to dash and type Virtualbox, click on the icon.
here is source url
