How do I install Google Chrome on my Ubuntu 13.10 easily? I had downloaded the file called google-chrome-stable_current_i386.deb from google downloads but it doesnot install using Ubuntu Software Center.
Open a Terminal and go to the folder where you downloaded the deb file an type:
sudo dpkg -i ./google-chrome-stable_current_i386.deb
It will install the package system-wide.
Add 3rd party repository for Google Chrome stable with these commands:
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
sudo sh -c 'echo "deb http://dl.google.com/linux/chrome/deb/ stable main" >> /etc/apt/sources.list.d/google.list'
sudo apt-get update
sudo apt-get install google-chrome-stable
Source: https://www.ubuntuupdates.org/ppa/google_chrome
karel
  • 122,292
  • 133
  • 301
  • 332
tarkhov
  • 386
For Installing chrome in Kubuntu 14.04, open KONSOLE then run the following commands
cd /tmp
For 32 bit :
wget https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb
For 64 bit :
wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
sudo dpkg -i google-chrome*; sudo apt-get -f install
muru
  • 207,228
  1. Go to download folder where that chromium.deb file is downloaded.
  2. right click and open terminal.
  3. wrote command to extract file.
    sudo dpkg -i filename.deb
  4. now install the pakage using below command.
    sudo apt-get install -f
After installation search for chromium application and you see it is installed in system.
muru
  • 207,228
