I need to install offline packages for a linux server. it is a repellent task because all the time it outputs that the package I want to install needs several other packages.
How can I resolve this problem, please ? Regards
Braiam
  • 69,112
You could try with dpkg-offline:
dpkg-offline obtains a package's dependencies, starting from a known set of packages (as for a base installation), fetches those .debs and packages them up in a tarball. Ideal for offline installation of the "seed" package.
First branch the project on launchpad:
bzr branch lp:dpkg-offline
dpkg_offline tutorial
Let's say you want to create a tarball with all the dependencies necessary to install git on an Ubuntu 12.04 server system.
Once you have dpkg_offline, ensure you have the needed dependencies installed:
sudo apt-get install genisoimage mtools squashfs-tools apt-utils curl
Once they're installed, get your seed .iso image::
wget http://releases.ubuntu.com/precise/ubuntu-12.04.4-server-amd64.iso
Now you're all set to do the installation. Run this:
./dpkg_offline ubuntu-12.04.4-server-amd64.iso "git"
The first argument is the seed iso, while the second is a list of packages to install. Using quotes is necessary so that the second "thing" is taken as the whole list. Of course, it's not necessary if you have only one seed package.
If the process completes successfully, a tarball will be left in the current directory. The name will encode the seed ISO, creation date, and the base packages that were installed:
apt-repo-ubuntu-12.04.4-server-amd64.iso-20131213-git_13a1.7.9.5-1_amd64.tar.gz
If something fails, dpkg_offline will tell you what failed and point you to a log file that may contain more details about the failure. This file will be in a temporary directory; dpkg_offline normally cleans this directory up, but in the case of a failure it will leave it as-is for analysis.
