10
My jenkins looks like corrupted. After installing older version I tried to upgrade. When I tried
wget -q -O - http://pkg.jenkins-ci.org/debian/jenkins-ci.org.key | sudo apt-key add -
sudo sh -c 'echo deb http://pkg.jenkins-ci.org/debian binary/ > /etc/apt/sources.list.d/jenkins.list'
sudo apt-get update
sudo apt-get install jenkins
It was failed to upgrade. Then I removed jenkins using
sudo apt-get remove jenkins
And again I tried to install.It is giving
    Reading package lists... Done
Building dependency tree
jenkins is already the newest version.
The following packages were automatically installed and are no longer required:
  libjna-java libhttpcore-java libxbean-java libargs4j-java libhttpclient-java
  libplexus-build-api-java libbackport-util-concurrent-java
  libplexus-utils-java libjffi-java libjffi-jni
  libmaven-common-artifact-filters-java libjsr305-java libcommons-jexl-java
  libplexus-bsh-factory-java libplexus-container-default-java
  libganymed-ssh2-java jenkins-cli libplexus-sec-dispatcher-java
  libcommons-net2-java libjsoup-java libmaven2-core-java libplexus-cipher-java
  libjenkins-remoting-java libeasymock-java libplexus-i18n-java
  libmaven-invoker-java libplexus-containers-java libjaffl-java libdoxia-java
  libmaven-dependency-tree-java libmodello-java libplexus-archiver-java
  libconstantine-java libmaven-scm-java libmaven-enforcer-plugin-java
  libplexus-io-java libwagon-java libcommons-vfs-java libanimal-sniffer-java
  libgoogle-collections-java libnetbeans-cvsclient-java
  libmaven-plugin-testing-java libplexus-classworlds-java libitext1-java
  libplexus-interactivity-api-java libcommons-jxpath-java jenkins-common
  libplexus-interpolation-java libclassworlds-java
  libcommons-configuration-java libjnr-posix-java libplexus-ant-factory-java
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 513 not upgraded.
But service jenkins restart command throwing
jenkins: unrecognized service
Even http://localhost:8080/ not working.
I want to install from beginning . Any suggestions?
Edited:
I followed these steps :
sudo apt-get update && sudo apt-get dist-upgrade && sudo apt-get install -f && sudo apt-get autoremove
and then same above steps followed to install.
But still same error.Again I tried to remove package using
sudo apt-get remove jenkins && sudo apt-get install jenkins
This is part of output:
The following NEW packages will be installed:
  jenkins
0 upgraded, 1 newly installed, 0 to remove and 268 not upgraded.
Need to get 0 B/61.3 MB of archives.
After this operation, 67.4 MB of additional disk space will be used.
Selecting previously unselected package jenkins.
(Reading database ... 224579 files and directories currently installed.)
Unpacking jenkins (from .../archives/jenkins_1.557_all.deb) ...
Processing triggers for ureadahead ...
Setting up jenkins (1.557) ...
But still service not recognized.
One more thing I noticed is /etc/init.d/jenkins is empty.
Any other way to install same jenkins package?
stefun
  • 203
Well, the package was removed so that is why it is not starting or running. Run sudo apt-get update && sudo apt-get dist-upgrade && sudo apt-get install -f && sudo apt-get autoremove In the future take care when installing packages from outside the ubuntu repos. IMO you are better off building from source or using a ppa.
From your description of the problem, your config file was somehow corrupted. simply removing and reinstalling a package will not fix the problem (it rarely does in Linux) because apt-get remove foo removes the libs and binary, but leaves the configuration files in place. When you then install apt-get install foo the config files remain.
To resolve this problem, IMO it is best to purge rather then remove a package (although if you prefer you can edit the config files to modify the behavior of apt-get).
sudo apt-get purge jenkins
If the problem persists you may need to file a bug report against jenkins.
Panther
  • 104,528
