I have trialed to use Network, NAP profiles on Bluetooth.
On Host, xUbuntu 13.04 I have followed as here.
This Host or XUbuntu machine is behind proxy & runs on virtual machine.
It is installed with Bluetooth version 4.101
On embedded board, ping 173.194.112.211 responds as below:
PING 173.194.112.211 (173.194.112.211) 56(84) bytes of data.
64 bytes from 173.194.112.211: icmp_req=1 ttl=46 time=336 ms
On embedded board, ifconfig shows as below:
bnep0 Link encap:Ethernet HWaddr 3E:DA:FB:6C:EE:BC
inet addr:10.220.129.178 Bcast:10.255.255.255 Mask:255.0.0.0
inet6 addr: fe80::3cda:fbff:fe6c:eebc/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:458 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:1793 (1.7 KiB) TX bytes:36870 (36.0 KiB)
eth0 Link encap:Ethernet HWaddr 0C:23:C0:80:C0:E8
inet addr:10.122.83.127 Bcast:10.255.255.255 Mask:255.0.0.0
inet6 addr: fe80::e23:c0ff:fe80:c0e8/64 Scope:Link
RX packets:24555 errors:0 dropped:611 overruns:0 frame:0
TX packets:20647 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3374125 (3.2 MiB) TX bytes:5878612 (5.6 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:25809 errors:0 dropped:0 overruns:0 frame:0
TX packets:25809 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3824780 (3.6 MiB) TX bytes:3824780 (3.6 MiB)
polo0 Link encap:Ethernet HWaddr 02:00:00:00:00:01
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ff:fe00:1/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:696 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:117357 (114.6 KiB)
On embedded board, I issue command: ping -I bnep0 173.194.112.211
This is google IP address by the way :)
After long time, I press Ctrl + c, it gives this:
PING 173.194.112.211 (173.194.112.211): 56 data bytes
^C
--- 173.194.112.211 ping statistics ---
541 packets transmitted, 0 packets received, 100% packet loss
On embedded board, I also trialed changing bnep0 inet addr to: 10.122.83.128.
For sure no one has this IP address.
It did not work...
hcidump -X shows these packets when I ping, not other times.
HCI sniffer - Bluetooth packet analyzer ver 2.4
device: hci0 snap_len: 1028 filter: 0xffffffff
> ACL data: handle 38 flags 0x02 dlen 47
L2CAP(d): cid 0x0042 len 43 [psm 0]
0000: 00 ff ff ff ff ff ff 3e da fb 6c ee bc 08 06 00 .......>..l.....
0010: 01 08 00 06 04 00 01 3e da fb 6c ee bc 0a dc 81 .......>..l.....
0020: b2 00 00 00 00 00 00 ad c2 70 d3 .........p.
I wish to access internet On embedded board, over Bluetooth, via xUbuntu's Ethernet's internet connection, NOT Ethernet of embedded board.
Someone please help me to get this working.
