I get this problems when i run apt-upgrade
libudev0 : Breaks: libudev0:i386 (!= 175-0ubuntu9.4) but 175-0ubuntu9.5 is installed
libudev0:i386 : Breaks: libudev0 (!= 175-0ubuntu9.5) but 175-0ubuntu9.4 is installe
I ran all commands I could come up with like clean, autoclean, install -f, dist-upgrade etc.
I think I need some more understanding of what this problem really is to solve it.
I tried to remove libudev0 and libudev0:i386
but it does not work either.
What is really going on here? I have had problems like Depends on but never Breaks
I tried to remove libudev0:i386 but failed:
buffalo@android-4c56l:/var/lib/dpkg$ sudo apt-get remove libudev0:i386
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
gvfs:i386 : Depends: libudev0:i386 (>= 147) but it is not going to be installed
libgudev-1.0-0:i386 : Depends: libudev0:i386 (>= 165) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution)
sudo apt-get install -f gives:
buffalo@android-4c56l:/var/lib/dpkg$ sudo apt-get install -f
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  language-pack-kde-en kde-l10n-engb openjdk-7-jre-lib language-pack-kde-en-base nvidia-settings-319-updates
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  libudev0
The following packages will be upgraded:
  libudev0
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/28.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: error processing libudev0 (--configure):
 libudev0:amd64 175-0ubuntu9.4 cannot be configured because libudev0:i386 is in a different version (175-0ubuntu9.5)
dpkg: error processing libudev0:i386 (--configure):
 libudev0:i386 175-0ubuntu9.5 cannot be configured because libudev0:amd64 is in a different version (175-0ubuntu9.4)
dpkg: dependency problems prevent configuration of libgudev-1.0-0:
 libgudev-1.0-0 depends on libudev0 (>= 165); however:
  Package libudev0 is not configured yet.
dpkg: error processing libgudev-1.0-0 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libgudev-1.0-0:i386:
 libgudev-1.0-0:i386 depends on libudev0 (>= 165); however:
  Package libudev0:i386 is not configured yet.
dpkg: error processing libgudev-1.0-0:i386 (--configure):
dpkg: dependency problems prevent configuration of udev:
 udev depends on libudev0 (>= 175); however:
dpkg: error processing udev (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
 libudev0
 libudev0:i386
 libgudev-1.0-0
 libgudev-1.0-0:i386
 udev
Tried to hold the packages then autoremove:
buffalo@android-4c56l:/var/lib/dpkg$ sudo apt-mark hold libudev0
libudev0 set on hold.
buffalo@android-4c56l:/var/lib/dpkg$ sudo apt-mark hold libudev0:i386
libudev0:i386 set on hold.
buffalo@android-4c56l:/var/lib/dpkg$ sudo apt-get autoremove
You might want to run 'apt-get -f install' to correct these.
 libudev0:i386 : Breaks: libudev0 (!= 175-0ubuntu9.5) but 175-0ubuntu9.4 is installed
E: Unmet dependencies. Try using -f.
Hold the packages libudev0,libudev0:i386 from being upgraded.
upgrade all installed packages
sudo apt-get upgrade
Now the error won't appears while upgrading.
Avinash Raj
  • 80,446
