/usr/lib/update-notifier/apt-check
is actually equivalent to stats returned by
apt-get -s dist-upgrade | grep "^[[:digit:]]\+ upgraded"
and not
apt-get upgrade|grep "^[[:digit:]]\+ upgraded"
For Example
/usr/lib/update-notifier/apt-check --human-readable
returns
22 packages can be updated.
0 updates are security updates.
whereas
returns
18 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
It actually 18+4 which amounts to 22.
From apt-get manual:
upgrade
upgrade is used to install the newest versions of all packages
currently installed on the system from the sources enumerated in
/etc/apt/sources.list. Packages currently installed with new
versions available are retrieved and upgraded; under no
circumstances are currently installed packages removed, or packages
not already installed retrieved and installed. New versions of
currently installed packages that cannot be upgraded without
changing the install status of another package will be left at
their current version. An update must be performed first so that
apt-get knows that new versions of packages are available.
dist-upgrade
dist-upgrade in addition to performing the function of upgrade,
also intelligently handles changing dependencies with new versions
of packages; apt-get has a "smart" conflict resolution system, and
it will attempt to upgrade the most important packages at the
expense of less important ones if necessary. So, dist-upgrade
command may remove some packages. The /etc/apt/sources.list file
contains a list of locations from which to retrieve desired package
files. See also apt_preferences(5) for a mechanism for overriding
the general settings for individual packages.
source
