I can not delete the "apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26" btrfs snapshot. Here are the details:
root@cioco:~# btrfs subvolume list -s /
ID 261 gen 246 cgen 245 top level 5 otime 2013-10-19 00:52:26 path @apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
root@cioco:~# btrfs subvolume list  /
ID 256 gen 334584 top level 5 path @
ID 258 gen 334134 top level 5 path @home
ID 261 gen 246 top level 5 path @apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
ID 267 gen 334580 top level 256 path var/lib/lxc/mythtv/rootfs
ID 268 gen 334584 top level 256 path var/lib/lxc/jira/rootfs
ID 278 gen 279278 top level 256 path var/lib/lxc/michele/rootfs
root@cioco:~# grep btrfs /proc/self/mountinfo
20 1 0:16 /@ / rw,relatime - btrfs /dev/sda2 rw,compress=zlib,space_cache
39 20 0:16 /@home /home rw,relatime - btrfs /dev/sda2 rw,compress=zlib,space_cache
root@cioco:~# btrfs subvolume delete /@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
ERROR: error accessing '/@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26'
However I can delete a snapshot created by me:
root@cioco:~# btrfs subvolume snapshot / root-snap
Create a snapshot of '/' in './root-snap'
ID 309 gen 334592 cgen 334592 top level 256 otime 2014-03-31 02:19:08 path root/root-snap
root@cioco:~# btrfs subvolume delete /root/root-snap
Delete subvolume '/root/root-snap'
EDIT1: There is nothing logged in the kernel log:
root@cioco:~# dmesg -c >/dev/null
root@cioco:~# dmesg
root@cioco:~#
But strace gives a hint:
root@cioco:~# strace btrfs subvolume delete /@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
stat("/@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26", 0x7fffe88ebb60) = -1 ENOENT (No such file or directory)
write(2, "ERROR: error accessing '/@apt-sn"..., 82ERROR: error accessing '/@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26'
) = 82
Edit2: I've mounted the volume...
root@cioco:~# mkdir /snapshot
root@cioco:~# mount /dev/sda2 /snapshot -o subvol=/@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
61 20 0:16 /@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26 /snapshot rw,relatime - btrfs /dev/sda2 rw,compress=zlib,space_cache
root@cioco:~# btrfs subvolume delete /snapshot/
Delete subvolume '//snapshot'
ERROR: cannot delete '//snapshot' - Invalid argument
root@cioco:~# strace btrfs subvolume delete /snapshot/
stat("/snapshot", {st_mode=S_IFDIR|0755, st_size=230, ...}) = 0
brk(0)                                  = 0x2206000
brk(0x2228000)                          = 0x2228000
lstat("/snapshot", {st_mode=S_IFDIR|0755, st_size=230, ...}) = 0
stat("/", {st_mode=S_IFDIR|0755, st_size=242, ...}) = 0
openat(AT_FDCWD, "/", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3
fstat(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 23), ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fd8ad2ae000
write(1, "Delete subvolume '//snapshot'\n", 30Delete subvolume '//snapshot'
) = 30
ioctl(3, BTRFS_IOC_SNAP_DESTROY, 0x7fff5f1e5878) = -1 EINVAL (Invalid argument)
close(3)                                = 0
write(2, "ERROR: cannot delete '//snapshot"..., 53ERROR: cannot delete '//snapshot' - Invalid argument
) = 53
root@cioco:~# dmesg
[3172764.459166] device label cioco-root devid 1 transid 336213 /dev/sda2
Edit3: Solution
root@cioco:~# mount /dev/sda2 /btrfs-root/
root@cioco:~# ls -l /btrfs-root/
total 0
drwxr-xr-x 1 root root 262 Apr  1 08:31 @
drwxr-xr-x 1 root root 230 Oct 16 22:53 @apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26
drwxr-xr-x 1 root root   6 Oct 16 22:13 @home
root@cioco:~# btrfs subvolume delete /btrfs-root/@apt-snapshot-release-upgrade-saucy-2013-10-19_00\:52\:26/
Delete subvolume '/btrfs-root/@apt-snapshot-release-upgrade-saucy-2013-10-19_00:52:26'
root@cioco:~# dmesg
[41113.537617] device label cioco-root devid 1 transid 337615 /dev/sda2
Any help would be appreciated.
The snapshot exists in the real root of the filesystem, which is not what you have mounted in /. You have the /@ subvolume mounted in /, so there is no such file with that name. You have to mount the real root volume somewhere and use that path to reference the snapshot.
Or you can use apt-btrfs-snapshot delete instead.
psusi
  • 38,031
