10
I'm having trouble playing DVDs. I've installed all the libraries and whatnot (ubuntu-restricted-extras, libdvdcss2, libdvdread4, etc.). I was getting a lot of I/O errors on my DVD drive at startup and when I tried to play a DVD.
But I just bought a new DVD drive and I'm having the same problem. I switched out the SATA cables and tried a couple different SATA ports on my mother board, so I'm pretty sure that's not the issue.
Basically, the situation is this. I start up and after BIOS loads, but before GRUB shows up, I get a quick error saying error: cdrom read error. Then I boot normally, and everything is seemingly great. If I put in a DVD, it mounts, but I'm not able to play it or copy the files off of it.
I did a dmesg | tail before and after putting in the DVD.
Before
[  119.467771] wlan0: direct probe responded
[  119.515673] wlan0: authenticate with 00:23:69:5b:30:0f (try 1)
[  119.519117] wlan0: authenticated
[  119.520288] wlan0: associate with 00:23:69:5b:30:0f (try 1)
[  119.522256] wlan0: RX AssocResp from 00:23:69:5b:30:0f (capab=0x411 status=0 aid=2)
[  119.522259] wlan0: associated
[  119.523002] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  119.840039] Intel AES-NI instructions are not detected.
[  119.976906] padlock_aes: VIA PadLock not detected.
[  129.770718] wlan0: no IPv6 routers present
After
[  256.096324] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[  256.096326] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[  256.096329] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[  257.539308] wlan0: authenticate with 00:23:69:5b:30:0f (try 1)
[  257.541105] wlan0: authenticated
[  257.541129] wlan0: associate with 00:23:69:5b:30:0f (try 1)
[  257.543374] wlan0: RX AssocResp from 00:23:69:5b:30:0f (capab=0x411 status=0 aid=1)
[  257.543378] wlan0: associated
[  273.100632] UDF-fs: Partition marked readonly; forcing readonly mount
[  273.126058] UDF-fs INFO UDF: Mounting volume 'DVD_MOVIE', timestamp 2002/04/15 14:14 (1ed4)
so no errors there. With my old drive I was getting a whole host of errors, none of which seem to be appearing now. Unfortunately they don't seem to be the cause of the problem.
Does anyone have any idea what's wrong or how I might diagnose this?
Just an update to the issue. I've just tried playing a DVD on the same computer running Windows 7 and there was no issue. So now I'm just confused. I assumed the error message at boot indicated a hardware issue, but Windows doesn't seem to care. So I guess it's just Ubuntu that has an issue.
Kris Harper
  • 13,705
To make your drive region free you need to flash new firmware onto it so that the drive itself will not check the region. This is knows as RPC1, search for rpc1.org. New drives won't read "out of region" DVDs.
Indulis
  • 41
I'm going to guess it's a quirk with the SATA chipset on your motherboard and this drive that Windows has sorted but Linux has not yet.
Please respond with some more information about your hardware, and perhaps update your BIOS. It might be initializing the hardware incorrectly.
Also, start with CDs that you know aren't non-standard or drm-ified. DVDs have region lock; non-standard CDs introduce errors or do things to freak out DVD drives (certain drives don't read DVD-RW's in certain modes as some sort of rudimentary anti-copying measure) but a standard Audio CD is usually a lowest common denominator.
Broam
  • 1,151
After booting into Windows and playing a disc there, the drive started to work in Ubuntu. Someone suggested that this is because Windows set the drive's region code. If you need to set a region code in Ubuntu, you can use this answer.
Kris Harper
  • 13,705
-1
To enable greater DVD support open Accessories;Terminal and enter the following two commands:
sudo apt-get install ubuntu-restricted-extras
sudo /usr/share/doc/libdvdread4/install-css.sh
htorque
  • 66,086
