I was just wondering what "Vi" means in Linux (the command used for editing files)?
Wikipedia has a concise and properly cited explanation:
The name
viis derived from the shortest unambiguous abbreviation for the commandvisualinex; the command in question switches the line editorexto visual mode.
http://en.wikipedia.org/wiki/Vi
Note that this does not mean that the full name of the text editor "vi" is still "visual" or, even, that "vi" currently stands for "visual" - the name of the editor is just "vi". The above quote just explains how the name originally came into being.
As Ben Voigt helpfully points out, the people (and websites) claiming that it stands for "Visual Instrument" are confusing it with another product unrelated to the text editor.
- 37,804
Vi is a screen editor for Linux, Unix and other Unix-like operating systems. Pronounced (vee-aye). Stands for VIsual.
Sources: http://en.wikipedia.org/wiki/Vi and http://www.techopedia.com/definition/10347/vi
- 63,229
If one goes back and looks at an old man page for vi, such as the one for SunOS 5.10 from '07:
SunOS 5.10 Last change: 16 May 2007 1
User Commands vi(1)
The vi (visual) utility is a display-oriented text editor
based on an underlying line editor ex. It is possible to use
the command mode of ex from within vi and to use the command
mode of vi from within ex. The visual commands are described
on this manual page; how to set options (like automatically
numbering lines and automatically starting a new output line
when you type carriage return) and all ex line editor com-
mands are described on the ex(1) manual page.
Or from Ultrix (latest release '95):
Name
vi - screen editor
Syntax
vi [ -t tag ] [ +command ] [ -l ] [ -r ] [ -wn ] [ -x ] name...
Description
The (visual) editor is a display-oriented text editor based on The com
mand and the command run the same code. You can access the command
mode of from within
And thus you have it: vi is from visual. This matches the pattern its ancestor editors: ex is the extended editor and ed is an editor.
There is no indication that this stands for anything else. Maybe Visual Interface (what I learned it as back long ago), but there is no documentation that it stands for anything other than visual.
