27
The Software up-to-date Option automatically download the upgrade for nginx. but While installing it's giving me the following error:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  nginx
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/434 kB of archives.
After this operation, 977 kB of additional disk space will be used.
(Reading database ... 291344 files and directories currently installed.)
Unpacking nginx (from .../nginx_1.4.7-1~precise_amd64.deb) ...
Thanks for using nginx!
Please find the official documentation for nginx here:
* http://nginx.org/en/docs/
Commercial subscriptions for nginx are available on:
* http://nginx.com/products/
dpkg: error processing /var/cache/apt/archives/nginx_1.4.7-1~precise_amd64.deb (--unpack):
 trying to overwrite '/etc/logrotate.d/nginx', which is also in package nginx-common 1.4.6-1+precise0
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Actually that file /etc/logrotate.d/nginx does not exist in this folder.
Tim
  • 33,500
zay7sev
  • 373
Run the below commands on your terminal,
sudo dpkg -P nginx-common
sudo apt-get install -f
If it's shows any dependency problem when uninstalling the above nginx-common package, then purge nginx-common package along with it's dependencies.
sudo apt-get purge nginx*
Before running the above command, don't forget to check the dependency packages which are going to be purged along with nginx.
sudo apt-get purge -s nginx*
Avinash Raj
  • 80,446
