I just installed Ubuntu 13.10, but the wireless is not working and no wireless networks are showing:
Command: iwconfig
Outputs:
eth0 no wireless extensions.
eth1 IEEE 802.11abg EEID:off/any
     Mode:Managed Access Point: Not-Associated Tx-Power-19 dBm
     Retry long limit:7 RTS thr:off Fragment thr:off
     Power Management:off
lo   no wireless extensions.
The lspci -nn | grep 0280
Outputs:
02:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless
Network Adapter [14e4:4727] (rev 01)
Command lsmod | grep -e b43 -e brcm -e wl
Outputs:
wl          4207474         0
lib802011   14352           2 wl,lib80211_crypt_tkit
cfg80211    479757          1 wl
The following commands:
sudo -i
apt-get purge bcmwl-kernel-source
echo "blacklist b43" >> /etc/modprobe.d/blacklist.conf
exit
Output is:
youssef@YoussefSiblini:~$ sudo -i
[sudo] password for youssef:
root@YoussefSiblini:~# apt-get purge bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
E: Unable to locate package bcmwl-kernel-source
root@YoussefSiblini:~# echo "blacklist b43" >> /etc/modprobe.d/blacklist.conf
root@YoussefSiblini:~# ^C
The out put of: lsmod | grep -e brcm -e wl and rfkill list all
youssef@YoussefSiblini:~$ lsmod | grep -e brcm -e wl
brcmsmac              562767  0
cordic                 12574  1 brcmsmac
brcmutil               15618  1 brcmsmac
mac80211              596969  1 brcmsmac
cfg80211              479757  2 brcmsmac,mac80211
bcma                   46670  2 brcmsmac
youssef@YoussefSiblini:~$ rfkill list all
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
Many thanks in advance.
Youssef
Please open a terminal and do:
sudo -i
exit
Reboot and let us have your report.
Does your ethernet start up if you try:
sudo ifconfig eth0 down
sudo ifconfig eth0 up
ifconfig
Is ethtool installed?
sudo ethtool -s eth0 autoneg off speed 100
If the ethernet is now working:
sudo apt-get update
sudo apt-get purge bcmwl-kernel-source
If you still are unable to connect the ethernet, blacklist wl:
sudo -i
echo "blacklist wl" >>  /etc/modprobe.d/blacklist.conf
rm /etc/modprobe.d/blacklist-bcm43.conf
modprobe brcmsmac
exit
Reboot and let us hear your result.
chili555
  • 61,330
