I have a simple question.
I have a disc particion to C, D and E on my Windows XP and I want to install Ubuntu.
Will I lose all my files from D and E (it's like 50 gb, and I don't have an external HDD) when I install Ubuntu? Or the system while installing it offers me options to save my files somewhere or...?
Tim
  • 33,500
Ok you wont lose windows XP or your files when you use the installer for Ubuntu you need to select the option to custom the hard drive using G parted usually the install along side windows option will allow you to resize the drive if C: is big like at lest 20 GB make c: into 2 10GB an use the new 10gb partition to install the Ubuntu OS the good thing is Windows XP only needs 8gb partition to work and this will leave all your other files and drives in place and only change the boot C: windows xp drive 10gb is enough to install Ubuntu and have the swap partition and if will also allow you to duel boot with windows xp
No you won't loose them.
If you want to dual-boot Ubuntu with XP,just choose to custom partition your hard disk and make a new ext4 partition for Ubuntu.
More details here : https://help.ubuntu.com/community/WindowsDualBoot
Alternatively, if you wish to replace XP, you can place Ubuntu in place of the present C: without affecting other partitions. Be sure to save your Documents, Pictures or any other important things from C: .
Welcome to Ubuntu!
anshulk
  • 101
YES. You are more than likely to lose your files if you do not know what you're doing.
This is a rather advance topic. If you want to keep both OSes, then you want to do a dual boot system as explain by others. However, there is not guarantee that you won't lose your data. If you cannot do a backup and your files are important, then it is NOT safe.
Alexis Wilke
  • 2,787
