Steam needs to install these additional packages: libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
[sudo] password for user:
E: The method driver /usr/lib/apt/methods/https could not be found.
Reading package lists... Done
Building dependency tree
Package libc6:i386 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  tzdata libdb1-compat locales libc-bin initscripts
Package libgl1-mesa-glx:i386 is not available, but is referred to by another package.
Package libgl1-mesa-dri:i386 is not available, but is referred to by another package.
  libgl1-mesa-glx
W: Duplicate sources.list entry http://dl.google.com/linux/chrome/deb/ stable/main amd64 Packages (/var/lib/apt/lists/dl.google.com_linux_chrome_deb_dists_stable_main_binary-amd64_Packages)
W: You may want to run apt-get update to correct these problems
E: Package 'libgl1-mesa-dri:i386' has no installation candidate
E: Package 'libgl1-mesa-glx:i386' has no installation candidate
E: Package 'libc6:i386' has no installation candidate
Press return to continue:
When I type in sudo apt-get update:
user@chrubuntu:~$ sudo apt-get update
When I type in sudo apt-get install ia32-libs
user@chrubuntu:~$ sudo apt-get install ia32-libs
Package ia32-libs is not available, but is referred to by another package.
  lib32z1 lib32ncurses5 lib32bz2-1.0
E: Package 'ia32-libs' has no installation candidate
user@chrubuntu:~$
P.S. I'm a total newbie at ubuntu/linux
I think you're using HTTPS mirrors (see the error about the missing method driver). You might want to switch to a non-HTTPS mirror (the default mirror is usually non-HTTPS), install apt-transport-https and then switch back to your HTTPS mirror. Then run apt-get update and try installing the other packages.
muru
  • 207,228
