17
example.txt is below
Restaurant: McDonalds
City: Miami
State: Florida
Address: 123 Biscayne Blvd
Phone: 911
Restaurant: 5 guys
City: Atlanta
State: Georgia
Address: 123 Peachtree Rd
Phone: 911
Restaurant: KFC
City: NYC
State: NY
Address: 123 Madison Square
Phone: 911
Im using bash script and lets say I want to search for a restaurant by its name from the file above. Ask the user input for the restaurant name and it should print the information regarding that restaurant (5 lines).
awk '/McDonalds/> /KFC/' example.txt
I know that line of code above will print the whole line that matches the pattern "McDonalds" and "KFC" but that will just print the 1st line from the text file but not the rest of the information about that restaurant. How can I tell it to print all of the information (5lines) from just the user input of the restaurant name?
terdon
  • 104,119
5 Answers5
16
With awk, you can change the record separator. By default it is a newline, so each line of the file is a record. If you set the RS variable to the empty string, awk will consider records to be separated by blank lines:
awk -v name="KFC" -v RS="" '$0 ~ "Restaurant: " name' example.txt
glenn jackman
  • 18,218
Using sed:
$ sed -n '/KFC/,/^$/p' file
Restaurant: KFC
City: NYC
State: NY
Phone: 911
$ sed -n '/McDo/,/^$/p' file
City: Miami
State: Florida
Phone: 911
Explanation
This is basic sed function, you can refer USEFUL ONE-LINE SCRIPTS FOR SED
# print section of file between two regular expressions (inclusive)
sed -n '/Iowa/,/Montana/p'             # case sensitive
d a i s y
  • 5,551
BMW
  • 170
$ awk '$2=="KFC" {print; for(i=1; i<=4; i++) { getline; print}}' example.txt
Restaurant: KFC
City: NYC
State: NY
Phone: 911
The above command will get and print the consecutive 4 lines along with the current line because it was fed into a for loop.The search pattern $2=="KFC" will helps to get a particular line from the multiple lines.
Avinash Raj
  • 80,446
Another possible solution:
awk 'BEGIN{FS="\n";RS="\n\n"}{if($1=="KFC")print $0}' example.txt
Jakuje
  • 6,793
Faisal
It is sufficient to print from line containing the name you want, to the last line containing word Phone ( assuming of course that all the entries follow the same pattern and will always have Phone as terminating record)
$> awk '/5 guys/,/Phone/' restaurants.txt
Restaurant: 5 guys
City: Atlanta
State: Georgia
Phone: 911
$> awk '/McDonalds/,/Phone/' restaurants.txt
City: Miami
State: Florida
Phone: 911
If we wanted to complicate it a bit, we could print exactly 5 lines after the match, like so:
awk '/McDonalds/{stop=NR+5}; NR<=stop ' restaurants.txt
City: Miami
State: Florida
Phone: 911
The stop variable will not be set, so NR<=stop will not print anything, until /McDonalds/{stop=NR+5;} part actually sets the variable, and that will only happen when we find the match.
d a i s y
  • 5,551
