I am installing Ubuntu Server 13.10 and cant get telnet working on the server. I have installed both xinet.d & telnetd thru apt-get and restarted xinetd but nothing is started when I do a netstat -l.
In googling, the trouble I see mention of adding telnet stream tcp wait telnetd /usr/sbin/tcpd /usr/sbin/in.telnetd line to /etc/inetd.conf. I have no inetd.conf. I see that inetd has been depracated and I put the line in xinetd.conf and restarted xinetd service but still no telnet listening. Can someone advise me on what the proper settings for the telnet server and what files they should be in. Here is the content of my xinetd.conf file:
# Simple configuration file for xinetd
# Some defaults, and include /etc/xinetd.d/
defaults
# Please note that you need a log_type line to be able to use log_on_success
# and log_on_failure. The default is the following :
# log_type = SYSLOG daemon info
includedir /etc/xinetd.d
#:STANDARD: These are standard services.
telnet      stream  tcp nowait  telnetd /usr/sbin/tcpd  /usr/sbin/in.telnetd
Thanks
