I am simply trying to have a few drives mount at startup of UBUNTU 12.04. I have tried entering the commands in startup applications (as explained in THIS tutorial):
udisksctl mount --block-device /dev/disk/by-uuid/32249C132BD865 (shortened)
udisksctl mount --block-device /dev/disk/by-uuid/FCE456F556B21E (shortened)
udisksctl mount --block-device /dev/disk/by-uuid/6A8C95BE8C958B (shortened)
After reboot the drives are not mounted. I can mount them simply by clikcing on the icons in pcmanfm or nautilus, but they remain unmounted at startup.
I have also tried to edit the /etc/fstab file as drescribed in the ANSWER HERE but can not locate any folder named "fstab", only a folder named "fstab.d" which seems to be empty.
I should also mention that the filesystems are NTFS
Any help would be appreciated.
The tutorial you followed was for enabling per-user automatic drive mounting within the graphical desktop. If you want the drive to be mounted at boot, regardless of user or graphical desktop, you do it with /etc/fstab, which is much simpler.
I'm not sure why the udisks method failed for you, but it isn't the approach I would take.
Your question seems to be confused about whether /etc/fstab is a file or folder. /etc/fstab is a file, which you should edit with a text editor.
User-friendly documentation for it is available here:
https://help.ubuntu.com/community/Fstab
thomasrutter
  • 37,804
I found another tutorial online (sorry lost the link on startup), but it was suggested there that for NTFS file systems that I get a utility called NTFS Configuration Too. It worked like a charm!
