I have received credentials for my University's network machine (Ubuntu yay!) that I have ssh access to. I would like to connect to it but first I need to connect through a gateway that I have specified in .rdp file received from my University.
On Windows I just double click on it and I have the session - first asking about domain credentials.
I have the following knowledge:
- username
- password
- gateway hostname e.g.
secretgateway.net - hostname e.g.
myhost.local - domain name e.g.
pluto - server port
3389
I know I can use likewise-open for connecting to windows domains but how do I specify it there since it is a remote network for me ?
EDIT after Remmina import ( there is no information about domain login nor the gateway)
EDIT2
I have also tried with xfreerdp :
xfreerdp /v:myhost.local /d:pluto /u:USER /p:PASS /g:secretgateway.net
and I get
transport_connect: getaddrinfo (Name or service not known) Error: protocol security negotiation failure
EDIT3
using new version of xfreerdp I get to launch my con.rdp file and I get the following
$ xfreerdp conn.rdp /p:PASS
autoreconnection enabled:i:1
devicestoredirect:s:*
drivestoredirect:s:*
redirectdrives:i:1
server port:i:3389
compression:i:1
keyboardhook:i:2
authentication level:i:0
promptcredentialonce:i:1
gatewayusagemethod:i:1
gatewayprofileusagemethod:i:1
gatewaycredentialssource:i:0
remoteapplicationmode:i:1
remoteapplicationname:s:ubuntu 12.04 v2.1 [60 GB HDD]
remoteapplicationprogram:s:||2fb6eb96-b458-11e3-92eb-00155d020101ssh_sr
full address:s:myhost.local
gatewayhostname:s:secretgateway.net
username:s:platon\wcss-d21d3q
connection type:i:5
displayconnectionbar:i:1
screen mode id:i:2
use multimon:i:1
redirectclipboard:i:1
redirectposdevices:i:0
redirectprinters:i:0
redirectcomports:i:0
redirectsmartcards:i:0
session bpp:i:32
allow font smoothing:i:1
allow desktop composition:i:1
disable wallpaper:i:0
disable full window drag:i:0
disable menu anims:i:0
disable themes:i:0
bitmapcachepersistenable:i:1
disable cursor setting:i:0
redirectdirectx:i:1
audiomode:i:0
audiocapturemode:i:0
videoplaybackmode:i:1
loading channel rail
connected to secretgateway.net:443
Could not open SAM file!
rts_connect error! Status Code: 401
HTTP/1.1 401 Unauthorized
Content-Type: text/plain
Server: Microsoft-IIS/7.5
WWW-Authenticate: Negotiate
WWW-Authenticate: NTLM
WWW-Authenticate: Basic realm="secretgateway.net"
X-Powered-By: ASP.NET
Date: Wed, 26 Mar 2014 00:19:57 GMT
Content-Length: 13
rts_connect error!
rpc_connect failed!
Error: protocol security negotiation or connection failure
WaitForSingleObject: pthread_join failure: 3
