28
I have a script that scans a directory and does some maintenance on the files in it. Another process creates the files in the directory (10 - 30 files per day).
The script is called via a daily cron job . What I need is to trigger the script on an event (each time a new file is created in the directory). I prefer this rather than increasing the frequency of the cron job.
How can I do that? is there a command or a program to install?
Thanks in advance for any help.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
5 Answers5
25
inoticoming
inoticoming is a daemon to watch a directory with Linux's inotify framework and trigger actions once files with specific names are placed in there.
For example it can be used to wait for .changes files uploaded into a directory and call reprepro to put them into your repository.
incron
incron is an "inotify cron" system. It works like the regular cron but is driven by filesystem events instead of time events. This package provides two programs, a daemon called "incrond" (analogous to crond) and a table manipulator "incrontab" (like "crontab").
incron uses the Linux Kernel inotify syscalls.
like cron, each user can edit its own incron tables.
Lekensteyn
  • 178,446
There is also a small program called iwatch - see the man page (this page is for Ubuntu precise (12.04), it has links to other ubuntu versions).
iwatch has the ability watch folders recursively (ie: subfolders too) and to send emails in response to file/directory events.
drevicko
  • 4,523
Another utility worth to know is fileschanged (man page here), that can monitor filesystem event on selected files or directories, for example the following command
fileschanged -s created -t1 $PWD
should monitor the current directory for file creation events, writing the name of the created file on stdout with a 1sec timeout.
fileschanged can watch folders recursively (as can iwatch as noted in another answer), unlike incron and inoticoming.
drevicko
  • 4,523
enzotib
  • 96,093
inotify man page is located there
if you prefer python scripts, you can use pyinotify
Pascal
  • 526
As of 2023, I'd recommend looking at fswatch or guard, which both work on many platforms.
RayB
  • 154
