I have two internet connections and I want to use them simultaneously in Ubuntu server to increase bandwidth and use this Ubuntu server as gateway for my LAN.
Asked
Active
Viewed 235 times
I haven't done this but I've thought about it. Isn't the bandwidth allocated at the modem/router? You basically assign the IP's/DNS to your web servers. Setup should be as simple as assigning two interfaces eth0,eth1 and rock and roll from there.
Kris
- 231
In short; you can't. The best you can do is to manually run some services, like a big download, over one connection, and other things like your web browsing over the other.
psusi
- 38,031
